help with the LS 1 EDIT
Old Apr 17, 2003 | 11:29 AM
Chevy Thunder's Avatar
Default help with the LS 1 EDIT
Does anyone have a 00' chev.silverado 5.3?
And if so, what extras have you installed?
I have lots of extras and one of them is
a larger cam. This cam has caused a problem
with my timing. My truck wants to die
when you come to a stop. I have the LS 1 EDIT
that you are supposed to use to fix this
problem but Iam not sure what to do. Does
anyone have any suggestions?
<small>[ April 17, 2003, 01:26 PM: Message edited by: Chevy Thunder ]</small>
Old Apr 17, 2003 | 01:12 PM
BigTex's Avatar
Default Re: help with the LS 1 EDIT
Welcome Keith. I agree with gremlin, raise the idle speed from the 550-600 range up at least over 750. Its going to depend on your cam. If you went really big, you might want it even higher.
Old Apr 17, 2003 | 02:02 PM
Scream's Avatar
MOOBIES Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by gremlin:
<strong> You probably need to bump up the idle some. The stock idle is 550 (I think). After the cam, I have my idle set at 700 and it runs fine. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Okay, now I'm scared. Am I going to have to bump my idle up with the 212/218 cam in my 4.8L? I talked to the guys at Thunder Racing and they said that I shouldn't have to.
Any thoughts?
Old Apr 17, 2003 | 03:20 PM
I had my 212/218 cam installed at Thunder Racing and they bumped up the idle for me, without even having to ask. They also made a slightly larger hole in the throttle body blade.
Old Apr 17, 2003 | 10:56 PM
Ryan23silverado's Avatar
look at my file over at www.ls1edit.com at the bottom of the page under "flash file library" for a 1999 truck. I idle at 600 in gear and 625 in park.
Sceam, I have NO driveability issues with my 208/216 .500/.500 lift cam. I bumped up idle a little to smooth out the engine from shaking. Sometimes I put it back to stock idle to hear it lope just for fun <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Apr 18, 2003 | 12:40 AM
wretched73
Oct 28, 2015 09:21 PM
sprayed99
Sep 21, 2015 04:47 PM
whippledstepside
Sep 17, 2015 05:02 AM
FormulaZR
Sep 14, 2015 05:23 PM
brandon_6667
Sep 6, 2015 04:49 PM
