Help.. I think?
Old Jun 3, 2015 | 09:44 PM
darnie's Avatar
Default Help.. I think?
Trucks a 2004 ext cab 5.3 trick turbo. 14 psi. Heads and cam
Heading home tonight I sped up after turning onto the highway turning home " the light started to change " and in doing so i broke tracking a little I peddled through the light prob got in and let out 2-3 times but in a quick burst 30-65 maybe? Neways now when I hit around 5+ psi there's a noise in the front end almost sounds like a hub barring but only under boost over 5psi. And weirdly it sounds like it's coming from the drivers side... Any ideas?
Old Jun 3, 2015 | 10:01 PM
ezdaar's Avatar
Here is a idea. Stop hauling *** through a changing red light.
Old Jun 3, 2015 | 10:03 PM
darnie's Avatar
I was making a turn and had the right away speed limit was 55 didn't do anything wrong... Neways...
Old Jun 4, 2015 | 08:35 AM
Choda's Avatar
weird. a wheel bearing would be an issue when ever your driving. Try turning the wheel all the way right and left to see it if makes noise. i would doubt its boost related, more like load causing the noise. Any vibration in the wheel?
Old Jun 4, 2015 | 10:16 AM
darnie's Avatar
Doesn't seem to have any vibration. And its only making the noise 5+ psi. It sounded like it's coming from the drivers side but could be wrong? I pulled the air filter off the turbo almost looks like a little wear maybe but Idk. Shaft spun great both ways and couldn't feel any play. Also believe my Pcv valve is no good so I'll be getting a new valve cover too :/
Old Jun 4, 2015 | 04:28 PM
darnie's Avatar
Looking at the turbo itself and to me the shaft has a good deal of play. And the housing is shinny where the blades would make contact? Only have maybe 3-4000k on the turbo but it is a cxracing one. There intro turbo. Not sure what to do from here. As far as that goes...
Old Jun 4, 2015 | 04:53 PM
ezdaar's Avatar
Buy another.
Budget turbo's are cheap.
Old Jun 4, 2015 | 05:24 PM
darnie's Avatar
kinda what im thinking.. im getting married in 3 months so $$$ is stupid tight if i get another one ill just paypal bill me later... question on that if i just get a cxracing trubo again should i get this one again...
cxracing.com: T76 1.15 A/R P Trim Turbo Charger 3" Vband Exhaust 4" Inlet V8 Rotary
This one
http://www.cxracing.com/mm5/merchant...ory_Code=TRBT4
Or get this one?
cxracing.com: T76 1.15 A/R P Trim Turbo Charger T4 Ball Bearing 4" Inlet 3" Vband Exhaust
Old Jun 4, 2015 | 05:35 PM
darnie's Avatar
http://vid786.photobucket.com/albums...psowwixyjp.mp4
Old Jun 4, 2015 | 05:47 PM
ezdaar's Avatar
that doesnt really look like much.
bushing based turbo's wiggle quite abit.
