Help, I locked up my engine today!!
Old Mar 27, 2008 | 09:21 AM
BigTex's Avatar
Before you take the time to check out the plugs, drain your oil into a bucket and look it over. That would take just a few minutes. If you have debris in the oil....
Old Mar 27, 2008 | 12:26 PM
Stoichiometric's Avatar
What valve springs did you have?
Old Mar 27, 2008 | 12:45 PM
CashDudeHomie's Avatar
918s. I hope they weren't one of the faulty batches. They were manufactured in May 2006.
Crap, I did a search and there were all kinds of failures from 2006 valve springs.
Old Mar 27, 2008 | 04:24 PM
Blue06's Avatar
Almost sounds like a converter problem. Maybe the clutch locked, and fragged.
Old Mar 27, 2008 | 05:38 PM
dlt76028's Avatar
Originally Posted by CashDudeHomie
Stock tranny with a 5 year old Yank 3000. If the converter just seized, I will be very happy as long as the tranny is ok.
how do you get away with a stock tranny with a radix 6.0 when mine starts slipping with just a 6.0? lol
Old Mar 27, 2008 | 05:45 PM
BigTex's Avatar
Have you seen his ETs? Its probably been slipping for a while.
Old Mar 27, 2008 | 05:52 PM
BigTex's Avatar
Hook up your tuning software and see what codes are showing.
Old Mar 27, 2008 | 09:57 PM
No trouble codes, other than the usual O2 sensor and speed sensor codes that have always been there.
I haven't felt any slippage, but it could be. I don't have much experience with transmission problems.
My ETs suck because Temple Dragway is absolutely horrible for anything but drag slicks. They had a Viper and Z06 running high 12's/low 13's last weekend.
Thanks again for all of the replies. If I don't find anything broken in the engine, how do I check the converter?
Old Mar 27, 2008 | 10:52 PM
Tootall's Avatar
put it in nutral, and take off the drive shaft from the trans . . . it "should" turn over by hand. Other than that I have no other ideas on how to "check" it.
pull the pugs and put a wrench on the crank . . . see if it spins over.
Are you sure that you didn't break a belt ?
Old Mar 29, 2008 | 03:31 AM
So... the first Comp 918 valve spring on the #7 cylinder broke along the topmost coil, dropping the valve into the cylinder. The spark plug wasn't damaged, but I didn't pull the head off yet to see what kind of mess there is.
I don't remember the spring batch#, but I remember the julian date showed them manufactured in late May 2006. They had a blue or green stripe. It was hard to tell which color it originally was, it is kind of a shade in between the two.
Anyone ever dropped a valve and NOT have catastrophic damage?
