Help Help Help!!!!!
Old Sep 25, 2007 | 09:20 PM
elrojo27's Avatar
Default Help Help Help!!!!!
ok guys well a few months back my truck would go into REDUCE ENGINE POWER all the time. after searching i found out that it was a bad ground....so all was good....fast foward today, i went to get my truck retuned after i installed the 4.10s and it started doing it again. everytime i would floor it it would go into REDUCE ENGINE POWER but in normal driving nothing would seem to be wrong. now Danny (aka RGVSIERRA) told me that the voltage was at about 12.3-12.5. could that be causing the problem??? how would i go about fixing it? another quick ? the other day i was replacing the oil dipstick and i am guessing some oil dripped onto something directly under thand caused several sparks. how would i know the PCM is fried??
Old Sep 25, 2007 | 09:21 PM
elrojo27's Avatar
all the wires from the battery seem to be tighten but i havent checked the ground. how many grounds are there?
Old Sep 25, 2007 | 09:43 PM
TouchOfEvil04's Avatar
several grounds. Not sure the exact number but off the top of my head at least....5
Old Sep 26, 2007 | 12:58 PM
elrojo27's Avatar
wouldnt happen to know their locations i so far found 2 the battery to engine, engine to chassis
Old Sep 27, 2007 | 06:08 PM
elrojo27's Avatar
well my truck only goes into REDUCE ENGINE POWER at WOT...any ideas????
Old Sep 28, 2007 | 11:35 AM
budhayes3's Avatar
PT's Slowest Truck
The starter is about where explaining that the sparks came from...you may have burned a fuse or fusible link...I'd check all of the fuses first.
Old Sep 28, 2007 | 11:40 AM
Nick™'s Avatar
voltage in the truck is at 12.3-12.5 with the motor running? that's way low, bad voltage is known to wreak havoc with the LSx motors.
Old Sep 28, 2007 | 12:44 PM
elrojo27's Avatar
we logged it after the truck went into REP mode, cleared the code and was running and it showed a 12.3-12.5 voltage. know i went to autozone the other day and the guy told me the battery and the alt were both good. how can i get voltage up? does the alt have an individual fuse??? whut is a fusible link?? sorry for the dumb ?s
Old Sep 28, 2007 | 12:54 PM
PappyDan's Avatar
Tribe Shaman
the link looks like a wire but will burn just like a fuse.
are you putting out a charge or you just reading the power of the battery.
you should be up around 14 or so on a charge gauge.
