Help with Gen iv intake swap
Old Feb 20, 2021 | 03:16 PM
timharber's Avatar
Default Help with Gen iv intake swap
I need help identifying this part: Its on the center top of the manifold. Also when putting a gen IV on gen III truck, what do you do about the purge valve/evap line?
Old Feb 20, 2021 | 08:09 PM
FFDP's Avatar
That's the PCV hose for the driver side valve cover. Looks like someone already broke the hard plastic line off it.
Not sure on the EVAP.
Old Feb 20, 2021 | 08:19 PM
arthursc2's Avatar
I used a C5 evap solenoid and 5/16 fuel hose. The plug was the same and the C5 solenoid has barbs on it
This was for a customers truck, not my own. Tuner had no issues keeping the MIL off and truck made ~530whp on *some* boost, and it never popped a hose off. I don't remember the boost pressure. Probably 12-15lbs
Old Feb 22, 2021 | 06:59 PM
RedXray's Avatar
100% Redneck
You have the 2009+ intake that has the factory molded PCV hose. The 2008 and earlier intakes have the PCV nipple molded on the intake requiring a simple piece of rubber hose to connect to the PCV valve. Not sure if you have enough nipple to secure a length of hose to that piece. If not you will need to replace that hose assembly (GM 12597774) and cut the lower end off to clamp a piece hose to the PCV valve.
You'll need the evap purge solenoid ACDELCO 2141680 and the solenoid to intake purge valve hose GM 12574897. To finish you'll run a length of rubber fuel hose from the evap solenoid to the evap line behind the engine.
GM 12574897
PCV hose assembly GM 12597774
Old Feb 24, 2021 | 09:50 AM
timharber's Avatar
Thank you! Ordered.
Tim
Old Mar 28, 2021 | 12:34 PM
tnbubba's Avatar
hey what duals you running?
Old Mar 29, 2021 | 09:29 AM
timharber's Avatar
Exhaust is still semi factory as I had just put on a Gibson S/S cat back. I'm not happy with it but it will work for now. I ran some Gibson sho0rty headers since I got them cheap.
Tim
elir_mn
Jun 12, 2015 12:11 AM
Cammed4ever
Oct 30, 2013 08:44 AM
moregrip
Dec 23, 2012 12:28 AM
desTRUCKtive
Jun 5, 2012 11:41 PM
