help fast header Q
Old May 19, 2005 | 09:46 AM
02chevyracing's Avatar
14 Second Truck Club
Default help fast header Q
I just installed the edelbrock shorties and the problem im having is exhaust leak from the flange to the headers. i used mr gasket paper gaskets. should i have used the stock donut gasket does anyone else sale gaskets. thakns Gene
Old May 19, 2005 | 09:58 AM
SSlow 4.8's Avatar
Are you using your stock bolts?
Old May 19, 2005 | 10:14 AM
no i had to cut two of the bolts so i bought bolts and nuts the passenger side sealed but the drivers side has a slight leak.
Old May 19, 2005 | 10:20 AM
SSlow 4.8's Avatar
hmmm... did u use those same paper gaskets? Your probably right, they might be the problem.
GaryG's Avatar
Central Autoparts down here carries felpro.. Try anywhere like that..
Old May 19, 2005 | 10:58 AM
11SECSS's Avatar
10 Second Club
If you bought the edlebrocks new it should have came with all the gaskets and bolts...if not try buying some felpros #1438 but make sure its not leaking from where the y pipe bolts on .
Old May 19, 2005 | 09:55 PM
okay i finally got it fixed up. i bought the felpro gasket for the drivers side and the donut gasket form the dealer and used a little high heat cilcone, no leaks. im happy. how many horse so you guys thinki got out of these shorties i was thinking 5 or 10. or is that to high? i only paid 70 plus 20 for the gaskets so i think its not that bad of a deal. i happy with the look.
Old May 19, 2005 | 10:10 PM
bluecajun5.3's Avatar
11 Second Truck Club
i have long tubes now but i use to have them edelbrock shorties. when i put them on i could definately tell a difference in the bottom end. i think you did good.
Old May 19, 2005 | 10:59 PM
v8
17,16,15,14,13,12,11 Drvr
well i ran a 13.67 through mine look at sig..
Old May 20, 2005 | 12:55 AM
i think once i put the posi with the 410s i might be in mid 13s im hoping. Gene
BigE
Feb 21, 2018 11:44 AM
murderedSS
27
Oct 12, 2015 11:13 AM
Superman09
Sep 25, 2015 05:55 AM
