help with exhaust
Old Dec 20, 2005 | 06:13 PM
MON-E-pIT's Avatar
Question help with exhaust
I just bought a 2001 silverado 1500 5.3 4x4.
I could not wait and just recently put a new set of asm headers on and cannot decide what I should do with my exhaust.
I would like to keep my stock cats for daily driving unless there is a way to pass a smog test w/o them. so cut outs will most likely be put in.
should i run x-pipe, or a y pipe, true duels etc... i would also like to dump the exhaust some place around my rear axle.
I will be installing a pretty big cam, built heads, converter, boltons and 125 shot, so i will need pretty good flow but not overkill.
I don't want it to be too loud for daily driving ( the girls wont like it)
thanks, any input will be helpful.[/FONT]
Old Dec 20, 2005 | 08:04 PM
CrabhartLS1's Avatar
The stock cats are fine unless you're running forced induction. I suggest either LTs to a Y pipe to a hooker aerochamber, or duals to aerochambers.
hooker aerochambers are good for quiet systems with LT's, they almost sound stock at idle, no drone, and only get loud at WOT. They flow just fine too. If you're not running cats, they'll still sound very good and mostly quiet.
Old Dec 20, 2005 | 09:04 PM
MON-E-pIT's Avatar
Can I pass inspection if i use o2 sims?
Old Dec 20, 2005 | 10:19 PM
depends on what's being inspected. If they only check codes and nothing else, then yes. If they do the sniffer, then you won't pass unless you plug your exhaust pipes with foam or something, which i've heard done but never actually done.
If they're doing a visual inspection, it again depends on whether they're strict enough to make sure the cats are in the stock location or if you just have cats period. If they're making sure the cats are in the stock location, you'll fail automatically with LT's, this would be states like California. If they're simply checking for cats and arn't concerned with the stock location, then you can get by with gutted cats.
Old Dec 20, 2005 | 10:27 PM
jchorner99's Avatar
arent you going to need a tune anyway.... then just have them turn off the rear 02's..
ive alwas liked the single 3" dump'd
Old Dec 20, 2005 | 10:33 PM
TXsilverado's Avatar
if your in texas its easy to get around the inspection...
Old Dec 20, 2005 | 10:46 PM
Last Call's Avatar
TOTM: January 2007
That must be nice. We in Cali get shitty 91 octane and some of the strictest smogs refs around.
Old Dec 20, 2005 | 10:52 PM
angelofdeath's Avatar
true that! i might take out my LTs when i get my smog. even my boys can't hook me up on my smog. they said the systems now are different.
Old Dec 20, 2005 | 11:03 PM
Last Call's Avatar
TOTM: January 2007
Sup Rein! Yea, your exhaust sounds sick. And smog in cali sucks ***!
Old Dec 20, 2005 | 11:28 PM
$thatguy$'s Avatar
in mississippi no body cares at all... we have nice farm land and clean air to polute haha
