help choose
Old Jul 10, 2006 | 07:03 PM
graysilv's Avatar
Default What do you all think???
hey guys i am about to change my spark plugs and i was wondering which one of these three would work better. any comments or suggestions are welcomed.
denso iridium
http://www.densoproducts.com/more_info.asp?pid=9781
ac delco iridium
http://www.acdelco.com/parts/sparkplugs/iridium.htm
ngk iridium IX
http://www.ngksparkplugs.com/product...420&country=US
Old Jul 10, 2006 | 07:24 PM
v8
17,16,15,14,13,12,11 Drvr
I've ran all three and there was no difference in them (on my truck) I run the stock A/C delco irridium plugs.
Old Jul 10, 2006 | 08:08 PM
99LoweredSierra's Avatar
i have the NGK iridium ix
Old Jul 10, 2006 | 08:10 PM
toneloc12345's Avatar
NGK tr55's were always a favorite with the LS1 crowd
Old Jul 10, 2006 | 08:58 PM
budhayes3's Avatar
PT's Slowest Truck
Any one of those plugs will work fine, you won't feel a difference between the three. I'm a fan of Denso's myself mainly because I have around 15 years working for Toyota and I know that Denso makes good stuff. I'm running NGK TR55's now since they're dirt cheap (between 1 to 2 bucks a plug), and as mentioned above the LS1 crowd seems to love them. I tried them out as an experiment, to see if there would be any difference between them, the Denso Iridiums I had before, and the factory platinum AC Delco's my truck came with. All three seemed to burn the same, and provide the same power and mileage as far as I can tell. The main advantage of Iridium plugs is longevity, they should last much longer than copper and also longer than platinum. Denso also claims a more complete burn leading to less carbon build up...but I have no solid proof of that.
BTW, I wouldn't doubt if all 3 of those Iridiums are basically the same thing with different names stamped on them...alot of guys have changed their factory original plugs to find Delco's on one side, and NGK's on the other. If you're dead set on Iridium, I'd probably go with whichever one you can get the best deal on.
sTNT971
Sep 26, 2015 04:22 PM
livefast1
Sep 25, 2015 07:31 PM
OHsixLS3
Sep 25, 2015 04:38 PM
laKebrada
Aug 28, 2015 02:18 AM
KEV5.3
Aug 24, 2015 08:00 PM
