HELP!!! Bank 1 lean
Old Jul 13, 2006 | 02:03 PM
  #21
JRsilverado's Avatar
Originally Posted by 01Blackerado
Another way to check the intake manifold, is to turn the truck on...grab a water bottle, and spray towards the intake manifold (not the K&N) . Make sure to spray very very little at a time incase you have a leak. If you have one, engine will stumble a little once you hit it with the water. DO NOT OVER SPRAY...keep it short and sparatic.
Thanks, I'll give that a try also.
Old Jul 13, 2006 | 02:50 PM
  #22
Originally Posted by JRsilverado
I'll kick you in the shins for that! I'm a FC
Sorry dude. Didn't mean to demote you like that. What ship?
Old Jul 13, 2006 | 09:06 PM
  #23
82streetshow's Avatar
is MAF descreened? that causes a crap load of problems or maybe even screened with something on it?
Old Jul 13, 2006 | 11:29 PM
  #24
Default lean
I got that message when i had a bad cat, i also had the same symptoms
Old Jul 14, 2006 | 05:01 AM
  #25
I'm running the stock MAF. I tried my Granatelli and nothing changed.
I beat on the cats and I didn't hear any rattle. Is that always a tell-tell sign?
Old Jul 17, 2006 | 10:28 PM
  #26
storm5.3's Avatar
13 Second Truck Club
I am having somewhat of the same problem right now, Bank 1 is lean... I'm not boosted but bank 1 is running lean after I changed out the o2's w/ the Bosch ones. Took it up to my tuner and he logged it and then we swapped 'em and bank 2 is still perfect but bank 1 got better (it was showing +25 and now its at +8 on the LTFT's). So we adjusted the tune a little and I was on the way back home and then the truck started bucking and running real rough when on the gas. Logged it and the bank 1 sensor was showing 45mV and not switching at all so I disconnected it to make it to the house. Can't figure this **** out. I guess I'll do more trouble shooting tomorrow...Zed
__________________
Old Jul 21, 2006 | 11:30 AM
  #27
Storm, did you find the problem???
The other day I changed the O2 sensors on the drivers side. It started running a little better. The more I got into the throttle, the better it ran. Till last night... I was driving home and it started running like ****! There was a point where I couldn't get over 45mph! It was bucking and wanting to die. I made it home. This morning, when I started the truck, there was a little bit of blue smoke at 1st! WTF??? It cleared up within a sec or 2. But the truck was idleing like I ended up parking it, and driving my room mate's Dodge 5.? non Hemi in to work What is the world coming to???
When it was running better but still surging, I would hear a lot of air pressure release then the truck would surge forward. Does anyone know what that would be?
I think it's clogged cats but I don't want to fork out the money for new cats just to find out that that's not the problem. I beat on them with my fist but I didn't hear any rattling...
Old Jul 21, 2006 | 12:02 PM
  #28
I forgot to mention... Last night I had a Bank 2 low voltage code, MAF code and a repeating EGR code. I didn't even think to write down the P numbers. Also, the right bank long and short term fuel trims were in the negative. What in the hell is going on???
Old Jul 21, 2006 | 09:59 PM
  #29
Does anyone have any ideas???
Old Jul 24, 2006 | 02:07 PM
  #30
01Blackerado's Avatar
What software are you using for tuning!!?? Ill give you a quick fix so you can drive without blowing up until you can figure it out!!
