HELP!!! Bank 1 lean
Originally Posted by CurtD
Swap the front o2 s from one side to the other and see if your problem switches sides. If so you need a new sensor.
Would a bad front O2 sensor effect the rear one? I'll give it a try.
Originally Posted by Doobie
Rear o2 monitors cat performance and front o2 monitors engine performance.
Thanks.
Another way to check the intake manifold, is to turn the truck on...grab a water bottle, and spray towards the intake manifold (not the K&N)
. Make sure to spray very very little at a time incase you have a leak. If you have one, engine will stumble a little once you hit it with the water. DO NOT OVER SPRAY...keep it short and sparatic.
