Help with 4.8 cam selection for my LS swap
I've got a 2003 4.8 that we are just putting new bearings and rings in. Its going into my 95 jeep yj. Because the 4cyl sucks.
while I got the 4.8 apart I am milling the heads to bump CR to 10.5. A little porting in the head.
Basicly a stock 4.8 with a CR bump and cam swap .
I have no idea what cam would be best for this setup. I know the 4.8 is not a powerhouse but it will wake my little jeep up.
jeep weighs 4100# with ls swap
has 4.88 gears
38" tires on 17" wheels
th350 trans - stock converter since it will be daily driven
e-fans
lt headers
I just want a little lope at idle with a decent tq curve across the board. A
any help will be appreciated.
has 4.88 gears
e-fans
lt headers
The following 2 users liked this post by FFDP:
cantbuytime79 (08-03-2021),
wretched73 (08-06-2021)
Post up some more info on the rest of this build!
Looks like you're gonna have a good time with this thing once its done.
cantbuytime79 (10-23-2021)
You should have a convertor with some stall with that combination. Probably 2500-2800rpm.
Although you have a decent rear gear, it's offset by the taller tires, so no real advantage there. You're on the smaller side being a 4.8 vs. the 5.3/5.7/6.0 that come in most trucks and LS1/6s. The other factor going against you is the TH350 only has 2.52 1st gear while the 4.8L would normally accompany a 4L60E with a 3.06. Might still work without a stall, but it's iffy.
The following 2 users liked this post by 68Formula:
arthursc2 (08-08-2021),
