help
Old Oct 15, 2006 | 05:07 AM
navy_ao_05's Avatar
dont care about gas how much faster will it be and how big of a cam i still wanna use it as my daily driver i just really wanna smoke hemis and lighting...but who doesnt... stupid question but what does flash to 4000 mean? so what gears should i get i wanna do 390s will those be ok??
Old Oct 15, 2006 | 10:10 AM
v8
17,16,15,14,13,12,11 Drvr
if its supposed to be for a camaro that weights in at 3700 and your truck weights in at 4500 then the 3600 stall becomes a 4000 stall. your truck wont move untill 3k rpms ahahahaa. good luck on the converter.
Old Oct 15, 2006 | 10:37 AM
navy_ao_05's Avatar
so v8 do you thinks worth it??? i do wanna be different!!
Old Oct 15, 2006 | 11:06 AM
v8
well its going to be very fast out of the hole if you get traction, DD you will lose about 3-4 mpg, it will get very hot in traffic, you will def. need a large tranny cooler to help keep temps down on the transmission, 01thunder has a 3500 stall converter in his and likes it, try it out and if you like it keep it, if not sell it to a camaro guy. Good luck on your quest.
Old Oct 15, 2006 | 11:11 AM
bluecajun5.3's Avatar
11 Second Truck Club
yeah, sell it to me if you don't like it
Old Oct 15, 2006 | 12:29 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Flash means, from a stop...you floor the gas...the engine will rev to 4000rpm before the TC will engage. Like dropping the clutch at 4000 rpm in a standard transmission. Traction will be hard to get.
The gears, I'm not sure about. 3.90 with that much stall in your TC...I dont think you'll ever get the tires to hook. You planning to but ET streets or something?
Old Oct 15, 2006 | 12:37 PM
litreddevil's Avatar
Banned
it will not fit any way the bell houseing is shorter on the f body than on the trucks
you will need to send it to them and get thicker pads where the verter bolts go
Old Oct 15, 2006 | 01:01 PM
so your saying that my tci converter pn. 242937 will not work.
humm, kind of strange since i've put 6k mi on it with no problems.
now i do understand that a vette converter will not work with truck or f body applications.
Old Oct 15, 2006 | 03:01 PM
Banned
that is a chance you are taking the bell houseing is a 1/2 shorter on a f body so yes it may work but it is not in the front pump like it should be now yes you can put washers but be careful that you don't put to many.
unless you changed your bell houseing
i wish i could get some pic up to show you i don't have any f body trans right now i will have 2 of them this week and i will try and get some pic up to show you.
Old Oct 15, 2006 | 03:40 PM
2000 SILVERADO's Avatar
How fast do you want to go? lol. I think you should get a 6.0L as well.
