HELP! 2008 silverado 1500 lost oil pressure!
Old Dec 12, 2012 | 02:37 PM
03sierraslt's Avatar
Cut the filter apart.
Old Dec 15, 2012 | 04:01 AM
CashDudeHomie's Avatar
When my oil pump went out (relief valve stuck open) I first heard the lifters ticking, so I looked down at the gauge and almost sh*t myself.
What do you mean the mechanical readings were the same? The same when it was running low, or when it was normal?
Old Dec 15, 2012 | 09:33 AM
andresz28's Avatar
how many psi is the normal readings? my lq4 reads 20-25psi at idle when its warm but it has an oil cooler...
btw from where do you read the oil pressure? in my mechanical gauge i read it from where the original oils pressure sender was... others says to read it from above the oil filter...
Old Dec 15, 2012 | 10:33 AM
darkostoj's Avatar
when i took the readings with the mechanical i did them in the same spot as the electric sensor and it was reading the same as the dash gauge.
I had another truck with a ly6 and i was having oil pressure problems with that one. When i put a mechanical behind the intake it would top out at around 40psi and idle around 15 psi hot. When i put the gauge at the oil port next to the oil pump on the left side of the engine i would have normal oil pressure. So its important to check for pressure at the port behind the intake
I pulled the motor out and the #3 cam bearing had spun out, put a new set of bearings in, put the engine back it and it was back to normal.
Old Dec 15, 2012 | 04:31 PM
FLREPOMAN's Avatar
i agree with above same thing happened to me in my dodge
chopperloco
Jul 10, 2016 10:45 PM
signguy62
Sep 20, 2015 02:05 PM
Cowboy Tom
Jul 21, 2015 10:29 PM
oharajo
Jul 18, 2015 09:24 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
