Heater hose connector
Old Jan 7, 2011 | 07:04 PM
topgun542's Avatar
Default Heater hose connector
well i was replacing the water pump and the connector broke... i need to know how to replace it and what to do. i got some pics just in case you dont know what im talking about.
Thank for the help!
Attached Thumbnails Heater hose connector-silvy-001.jpg   Heater hose connector-silvy-002.jpg   Heater hose connector-silvy-003.jpg   Heater hose connector-silvy-006.jpg
Old Jan 7, 2011 | 09:16 PM
BINNCZ71's Avatar
Default Mine did that bout two months ago
gm makes a special took to remove them... They are plastic fittings with finngers that grab the heater core fitting all the way around. Its a real pain.
You can try using fule line disconnect kits and some force and eventually work them off. It will take some time and effort..
Best of luck to you...
Old Jan 7, 2011 | 09:49 PM
Bluchevypick's Avatar
I always use the ac disconnect tool. If you cant get it with that then just cut it off with die grinder and replace with straight heater hose.
Old Jan 8, 2011 | 01:13 PM
white1's Avatar
I cut mine off with a hack saw blade
Old Jan 8, 2011 | 01:24 PM
lowslung85's Avatar
You can run to autozone or orilleys they sell a set of white quick disconnects they will work used em quite a few times had no problems, when you go to remove it first shoot some wd40 or pb blaster in the back side of the connector and this will help to get it broken loose.
Old Jan 8, 2011 | 02:59 PM
quicksilverado's Avatar
I cut mine off with a rotozip.
Old Jan 8, 2011 | 08:33 PM
topgun542's Avatar
well i went to oreilys and got the connector... its the black one but the label says for inlet or outlet. i put it on but didnt hear a click or anything. im hoping is stays and doesnt shoot off when i turn on my heat.
Gadgetized
Oct 22, 2015 09:06 AM
lxcoupe
Sep 25, 2015 12:36 PM
kalikid06
Sep 20, 2015 07:46 PM
kmcn47
Sep 17, 2015 01:12 AM
BlackGMC
Sep 9, 2015 01:43 PM
