Heat wrap
Old Sep 22, 2015 | 07:15 AM
03sierraslt's Avatar
Default Heat wrap
Who makes the best heat wrap? And is it best to apply dry or wet? This is for long tube headers ( not mine)
Old Sep 22, 2015 | 08:45 AM
BlackGMC's Avatar
Resident Retard
DEI makes some good stuff, that is what i used on my turbo stuff..
Old Sep 22, 2015 | 08:57 AM
quicksilverado's Avatar
Apply it wet. When it dries it will shrink and be much tighter on the headers. Make sure and wear gloves or you will be hating life.
Old Sep 23, 2015 | 10:24 AM
01silvy's Avatar
^^^^ Agreed!
Old Sep 23, 2015 | 10:40 AM
GMCtrk's Avatar
DEI titanium. Apply dry.
Old Sep 23, 2015 | 12:16 PM
smokeshow's Avatar
Mod with training wheels
I've tried applying it wet, I've tried using the more expensive stuff. Now I just buy the cheap crap, wrap it dry, and tighten the **** out of it...works great. And luckily it doesn't bother my hands at all...sounds like fiberglass wrap really tears up some peoples hands.
Old Sep 23, 2015 | 12:42 PM
RS/SS 4.8's Avatar
10 Second Truck Club
DEI basic heat wrap. Apply it wet and dont need gloves.
Old Sep 23, 2015 | 12:48 PM
fullboardmax's Avatar
I used dei titanium. I applied it wet because that's what the directions suggested. I recommend gloves just to keeps your hands from turning black.
Old Sep 23, 2015 | 02:01 PM
Choda's Avatar
i used cheap stuff and DEI titanium. Both wet. Pull it tight and I over lap 1/2 not 1/4 like the directions. Yes youll go through more but its worth it.
Let dry for 24 hours.
Use high temp DEI silicone paint with two decent coats. I just re did my cross over.
Old Sep 23, 2015 | 03:06 PM
ezdaar's Avatar
I have used expensive 60$ to cheap 17$ rolls.
Both wet and dry.
I prefer to suffer and install it dry with stainless hose clamps.
Hate both!
Seriously tho, expensive DEI wrap is 100X easier install.
Less fiberglass splinters, smoother appearance once installed and seems to work better (1/2 overlap). Tested with infrared temp gun and touching and the amount of carbon that comes out during install.
They way I like to do it now. If given the chance.
High end DEI up top where visible, where high temps really matter and on technical wraps.
Cheap ebay down below, not visible and needing to cover large sections of pipe and overall performance isn't really a issue.
