Heads or Nitrous???
Old Nov 21, 2006 | 08:18 PM
ap2002's Avatar
Originally Posted by CHEVY6000VHO
That's 12.5 with a 100 shot of gas!
You can do that too if you add what I PM'ed you.
Jim
nope you are wrong!!!! 12.5@105mph N/A with my 6.0!!!
times in the sig are from my 5.3....
Old Nov 21, 2006 | 08:45 PM
Oh, ooppss! Didn't notice.
Jim
Old Nov 21, 2006 | 08:52 PM
ap2002's Avatar
Jim
yup you got alot of catching up to do....
by the way, I think I will keep the nitrous and save for some heads... I got alot of reading to do before I buy the heads, I want to do it right the first time..... and yeah the suspension will have to ge first....
Old Nov 21, 2006 | 09:30 PM
I'm with you in the suspension department.
I'm almost finished with it. Just need to install carrier bearing relocator bracket, measure all u-joint angles, and pinion angle. Possibly shim the rear axle. No big deal because I will have the capability to shim from 1* all the way to 5* on the axle. I have enough shims now!
Nice times BTW!
Not sure my set-up will hang, but I'll sure out pull you!!!!
May be calling you up for some help with the engine mods. If I ever get around to it!
Jim
Old Nov 22, 2006 | 12:40 PM
TXsilverado's Avatar
Jim
and he will refer you to his engine builder
Old Nov 22, 2006 | 12:55 PM
bluecajun5.3's Avatar
11 Second Truck Club
Originally Posted by onebadrubi
if you get worked heads then you owuld IMO need a bigger cam. I think high 500's, .580/.590 lifts are good on stock heads. With worked heads I would want a little more lift. Something to consider, and of course it will help. And then agian with the heads your gonna want to consider an intake manifold(I think your still on the truck intake?)
not always true. look at the car guys running 224's on afr heads with great results. peak power is good but under the curve, especially for a truck is what really matters.
Old Nov 22, 2006 | 04:40 PM
Wink
Now, that's lazy AP!!!!!!!!
Jim
Old Nov 22, 2006 | 05:55 PM
ap2002's Avatar
Jim
why lie?? I am lazy and I dont know enough...
Greatdivider
Sep 9, 2015 09:52 AM
slowlsx
Aug 10, 2015 05:33 PM
USMCvet0311
Jul 29, 2015 01:28 PM
sauldgold
Jul 23, 2015 02:15 PM
