Heads, New Cam, and Intake install on my 4.8
Old Mar 20, 2009 | 11:20 AM
  #131
BlackGMC's Avatar
Resident Retard
True true... Well at least the day is half over, Thank Goodness...
BTW the cam shipped today!!!!!!!!!!!!!!!!!!!!!
Old Mar 20, 2009 | 11:57 AM
  #132
fastrt's Avatar
11 Second Truck Club
i am ready to go RACIN'
Old Mar 20, 2009 | 12:18 PM
  #133
hirdlej's Avatar
Should be there by the middle of next week, enjoy! I finally got my degree wheel in the mail today, I'm going to try and beat you installing my FTI cam. We'll see who enjoys theirs more BTW Corey, are you going to replacing your timing chain set? Going to degree everything in?
Old Mar 20, 2009 | 12:19 PM
  #134
00ChevyScott's Avatar
Wearin' da big hat
Why do you need a degree wheel
Old Mar 20, 2009 | 12:28 PM
  #135
hirdlej's Avatar
To verify your valve events and make sure that everything is running perfect. You'd be silly to install a camshaft without degreeing it. There are too many variables to a valvetrain that can affect valve timing. You need to make sure everything is working hand in hand to obtain perfect valve event timing.
Old Mar 20, 2009 | 12:36 PM
  #136
Wearin' da big hat
You better run a damn good time with all the trouble you go through with your setup
Old Mar 20, 2009 | 01:22 PM
  #137
fastrt's Avatar
you are running an adjustable timing set right? I thought lsx motors stock are non adjustable, so degreeing the cam is only good to see if the cam is cut right, right?
Old Mar 20, 2009 | 01:23 PM
  #138
GMCtrk's Avatar
If the cam is installed dot to dot and the cam was cam doctor'd, I don't see why you'd need to degree it.
Old Mar 20, 2009 | 01:29 PM
  #139
BlackGMC's Avatar
Resident Retard
I am about 99% sure i will be replacing the chain, and getting a degree wheel, i have always wanted to learn how to use one! And my cam being 108 LSA might be tempermental to say the least...
Old Mar 20, 2009 | 03:08 PM
  #140
hirdlej's Avatar
I'm installing my adjustable progear setup this weekend - you are correct in that a factory timing set is non-adjustable.
