Heads/Cam driving impressions after three days
Old Feb 28, 2005 | 01:37 PM
Yelo's Avatar
Default Heads/Cam driving impressions after three days
Well, Three days of driving around with this new setup and I'm pretty impressed !!
The computer is starting to figure out this new setup a little I think....the idle quality is alot better than the first night, the hot start issues are pretty much gone and the mid-range/part-throttle power is UNBELIEVABLE !!!
Tuning is a MUST.....at least it is if I want to pull the max out of this cam, I COULD drive it forever like it is but I really think tuning is gonna improve it dramatically
Part-throttle power is WILD !!!...I've never felt a cam that would pull this good at part-throttle, I've also noticed it takes ALOT LESS pedal to do the same work as before
I still think I'm leaning out in the upper-rpms....it's got a hesitation above 4800 or so that I'm pretty sure is due to a lack of fuel (it surges a little and is less rev-happy than it is below that rpm)
Old Feb 28, 2005 | 02:15 PM
Scream's Avatar
MOOBIES Moderator
Congrats man. Sounds like you're having a good time w/ it.
Old Feb 28, 2005 | 02:16 PM
BlownChevy's Avatar
blownerator
25 Year Member
Sweet! Glad to hear it all came together.
Old Feb 28, 2005 | 02:20 PM
moregrip's Avatar
what a rush!
yeah!!!!
Old Feb 28, 2005 | 02:22 PM
what kind of headwork did you have donel and how much did it cost?
Old Feb 28, 2005 | 02:57 PM
Yelo's Avatar
All I did was polish the chambers....and I did that work myself
I REALLy think the smaller intake ports of the LS1 heads are contributing to the extra torque that I'm feeling at low-rpm's
Old Mar 3, 2005 | 10:17 AM
marc_w's Avatar
Exactly what I've been trying to convey!
I've got some very interesting torque numbers from HPTuners 'delivered torque' parameter. The numbers are 385 at 2,100rpm... peaking 435 between 3,500-4,500... 400 at 5,200, and 350 at 6,000.
Leaving the actual numbers out of things, that's a WHOLE LOT of the max torque available, way down low...
Old Mar 3, 2005 | 11:10 AM
AKZ71's Avatar
Arrg...I need to get my 047 installed! Congrats on getting it in!
Old Mar 3, 2005 | 01:19 PM
Zick's Avatar
How much lope is there in that cam?
Glad you had good results
Old Mar 3, 2005 | 03:43 PM
Yelo's Avatar
Mine lopes pretty good right now.....but the idle is a little too low so that's contributing to the lope alot I think
I've got a little bit of a stalling issue too....but only when hot so I think it's got alot to do with the idle speed, I think that raising the idle about 75-100 rpm will cure my problems completely...I idle at 550 right now, 625-650 should fix all of my idle and hot-start issues
