heads
Old Nov 25, 2008 | 05:58 PM
454navyss's Avatar
Default heads
what are the stock heads on a 2002 5.3? would a set of 241s resurfaced .010 and fully refreshed 25000 miles ago be worth swapping?
Old Nov 25, 2008 | 06:16 PM
tallChevy's Avatar
no the 241s are not good heads. maybe some 243s. or just save some money and get some ported 5.3 heads.
Old Nov 25, 2008 | 06:35 PM
dirt track racer 81's Avatar
still just to have 243s you have to have them milled quite abit to retain stock compression ratio
Old Nov 25, 2008 | 10:18 PM
fastrt's Avatar
11 Second Truck Club
are they 706's? some one chime in.....if so I would keep the 706's and do a pnp and step up on the valves and a .030" mill and bump up compression in the 10.X to 1 range.
Old Nov 25, 2008 | 11:21 PM
southern_chevy's Avatar
I am with him^ find you a good machine shop around there and let them work over a stock set of heads and will them .030-.040.
Old Nov 28, 2008 | 11:37 AM
cwalker2006's Avatar
if you mill the stock heads that much. will it require you to use premium octane fuel?
Old Nov 28, 2008 | 05:25 PM
fastrt's Avatar
yes, but gas is $1.50 a gallon....so I like the higher comp idea, I wonder how much it will bump up power?
Old Nov 28, 2008 | 05:40 PM
Bo185's Avatar
And it will be $4.00 again just as quick!
Old Nov 28, 2008 | 06:32 PM
regency's Avatar
try looking for some 799 heads. chambers of a 5.3 and runners of a 243. so ive read anyways
Old Nov 29, 2008 | 02:22 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
no, the 799 have 64cc chambers, they are identicle with the 243's.
