Heads!!!!
Old Feb 15, 2007 | 04:36 PM
Default Heads!!!!
I wanted to know the diffrence between the 5.3L heads. I have seen casting numbers 862 and 706 is there a diffrence?????? Can any body tell me
Old Feb 15, 2007 | 04:59 PM
v8
17,16,15,14,13,12,11 Drvr
yep the 706 heads flow better
Old Feb 15, 2007 | 05:20 PM
I think The 706's are sand casted and flow better.
Old Feb 16, 2007 | 12:18 AM
WJ MARK's Avatar
Default what about 6.0 heads
Ive seen people using 6.0 heads. Whats different about them compared to a 5.3? larger valves?
Old Feb 16, 2007 | 08:29 AM
Richard@WCCH's Avatar
FormerVendor
We've flow tested dozens of stock truck castings over the years and when averaged out, both the 706 and 862 have near identical flow. Some are better than others due to seat lineup and core shift, but for the most part they matchup pretty close.
The 6.0l heads have a larger intake valve, different port cores and larger chambers due to the 4.0" bore they sit on.
Good luck.
Richard
Old Feb 19, 2007 | 10:54 PM
airdeano's Avatar
richard.. how much would one have to "shave" from a 6.0L (LQ4) 71cc chambered
head down to a 5.3L (LM4/7) 62cc? gotta be in the .060-.075" range..
isnt that a bit to remove from a head with some sealing issues..
airdeano
Old Feb 19, 2007 | 11:02 PM
i am buy some 706s i am planning on getting them work on what should i do to them?
milled them down 0.030" bigger valve sizes ported and polished them
Old Feb 19, 2007 | 11:35 PM
FormerVendor
airdeano
You'll need to mill about .050" to get from 71cc to 62cc with a 317 casting. Sealing the head gasket shouldn't be a problem with n/a setups, but might be a big problem with blown applications.
Richard
lsxmalibu
Sep 9, 2015 11:08 PM
03regcab sierra
Sep 9, 2015 02:02 PM
axekick
Sep 7, 2015 07:01 PM
sauldgold
Jul 23, 2015 02:15 PM
Aboss
Jul 9, 2015 10:28 AM
