Heads
Old May 25, 2005 | 06:37 PM
mattrem's Avatar
I quess you are working towards your 05 goal then. I would say you have them. Thanks for the help.
Old May 26, 2005 | 08:29 PM
moregrip's Avatar
what a rush!
hmm, I wonder how some 1 3/4" long tubes with 3" collectors would work with these WCCH stage2 heads?
Old May 27, 2005 | 07:40 AM
mattrem's Avatar
I might find out before you. I talked to Richard yesterday. These heads are perfect for my cam. I know they will work well with my Dynatechs.
First I am going to the track next Wednesday for the first time with the SS, then I can see what I have now.
Old May 27, 2005 | 07:42 AM
moregrip's Avatar
what a rush!
I have to say, Richard from WCCH, is a stand-up guy in my book
Old May 27, 2005 | 09:32 AM
mattrem's Avatar
So when are you bolting on your set? What cc chambers did you get?
Old May 27, 2005 | 03:58 PM
Richard@WCCH's Avatar
FormerVendor
Recently one of our 6.0l heads were flow tested at Bob Lambeck's shop on his Super Flow 1020 flow bench. Here's how they did.
Lift Intake Exhaust
.100" 70.8 60.0
.200" 147.0 115.7
.300" 209.1 162.4
.400" 250.7 213.6
.500" 289.6 225.5
.550" 305.2 226.3
.600" 290.2 227.3
The runner volumes are intake 232cc and exhaust 88cc. The chamber volume with minimum milling is 74.5cc.
The intake was tested with a radiused flow plate and the exhaust was tested with a short exhaust tube. Both tests were done on a 4.030" bore fixture. We worked hard to get the mid lift flow as high as possible without sacraficing too much high lift flow. I feel this setup will work very well for aspirated and supercharged truck engines because they typically don't run large lift cams. The intake port flow peak occurs at .575" lift, while the exhaust is pretty much done by .500".
As mentioned previously, we're selling these head packages currently for $1300.00 per pair exchanged. If you need us to supply cores, we can do so. Core charges vary depending on availability, but they usually range in price from $300.00 to $400.00.
Feel free to call or email me if you have any further questions.
Regards,
Richard
Old May 27, 2005 | 04:44 PM
moregrip's Avatar
what a rush!
those are some very solid numbers Richard! thanks for the info They are a big improvement over stock for sure.
Old May 27, 2005 | 04:45 PM
BlownChevy's Avatar
blownerator
25 Year Member
Bob Lambeck, now there is a name from the past!!
Old May 27, 2005 | 05:49 PM
FormerVendor
Lol.........he's still kickin **** and takin names
Richard
Old May 27, 2005 | 06:55 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
No offense to Richard, but I love my TEAs stage IIIs
