Headers vs. cab noise?
my long tubes are very noticeable in the cab, in fact i thought i had an exhaust leak after the install. during light throttle you can hear a slight tiny sound from under the dash, must be the valve train noise or the sound of each cylinder firing coming thru the thin long tubes. I like the sound.
Installed my Longtubes with 3" piping and a magnaflow, and it sounds A LOT quieter than what I had with my stock manifolds, no cats, and the magnaflow.. well that is until I floor the pedal then it sounds Bada**
04 GMC Sierra Exhaust - YouTube
Ive got pacesetter LT's through the ORY and stock muffler/tailpipe.. It makes noise in the cab but its not bad enough to bother you on roadtrips, I mostly hear mine when its high engine load, cruising rpm with the radio off.. When your on the highway at 70-75 mph the wind and normal highway noise will cover up the sound of the LT's.
Stainless Works
Apr 10, 2016 04:34 PM
FlowmasterMufflers
Oct 26, 2015 06:19 PM
superchomper2003
Aug 26, 2015 09:39 AM
