09/10 5.3 vs 6.0 "TBSS" intake
Old 10-27-2010, 08:22 AM
Shon Herron's Avatar
Default 09/10 5.3 vs 6.0 "TBSS" intake
Is there any difference between the 2 other than the casting number?
I picked up a TBSS take off intake but the casting number comes up as a 5.3 intake.
And is the intake seal/gasket really $100ish!?!? HOLY COW...showing part number 89060413.
Old 10-27-2010, 08:25 AM
blsnelling's Avatar
That is the correct PN. You can probably reuse your old one. If you end up with a vac leak, it's simple enough to pull off and replace. BTW, you can get that gasket for $80 from sponsors.
Old 10-27-2010, 08:27 AM
Guess I need to see what "gasket" set up is on this LQ4, I was expecting to have individual gasket seals....and I looked at one sponsor and saw $100+, will keep looking!
What about difference between the intakes?!?!?
Old 10-27-2010, 08:43 AM
blsnelling's Avatar
The gasket is a plastic spacer with rubber seals on both sides. There is one for each side of the intake.
Old 10-27-2010, 08:59 AM
did your 04 LQ4 have this gasket or ndividual port seals (like LS1+ intakes)?
Old 10-27-2010, 09:44 AM
blsnelling's Avatar
One gasket per side on both the 6.0 and 5.3.
Old 10-27-2010, 10:05 AM
Thanks!
What direction does the truck DBW TBs open? My cable one is from counter clockwise when looking at the cable. I was hoping to still run a cable style TB but don't want to mess up the air flow as some have seen with a car TB
Old 10-27-2010, 10:06 AM
Thanks!
Old 11-10-2011, 12:18 AM
BadAssChevy327's Avatar
bringing this back. has it been confirmed then use the same intake gasket as my 05 lq9 has?
Old 11-10-2011, 05:18 AM
Banned
364HC's Avatar
isn't it the same intake.
Quick Reply: 09/10 5.3 vs 6.0 "TBSS" intake
