Headers with Radix?
Old Feb 8, 2005 | 02:53 PM
OCBC's Avatar
Default Headers with Radix?
How does the radix run on a truck with headers?
The tech guy at the local dealer that installs the magnacharger mentioned that headers would hurt the radix performance.
Thanks
Old Feb 8, 2005 | 02:56 PM
BlownChevy's Avatar
blownerator
25 Year Member
I would suggest the Dyantech headers if you are lucky enough not to be in California!
No headers with a Radix.....what dealer was this??
Old Feb 8, 2005 | 02:59 PM
OCBC's Avatar
I am a cali boy. I was looking at the TOG's. Blown, whats your opinion on those?
My local GMC dealer in O.C.
He said the headers would let it flow too much! I know very little about the technical side of auto mechanics and I still smelled something foul when he said this.
Last Call's Avatar
TOTM: January 2007
Thanks
I have TOG's on my truck with the Radix. I don't see how headers would hurt performance. Power is just a function getting as much air/fuel into and out the engine and headers help get rid of the exhaust from combustion.
However, headers may lower the boost you see because exhaust is leaving faster than air is coming in. I know when I had my flowmaster, 9lbs of boost were seen with the 3.4 pulley.
Old Feb 8, 2005 | 03:03 PM
BlownChevy's Avatar
blownerator
25 Year Member
The TOG's are nice, infact they are CARB legal. You can expect 20 or so rwhp with a good set of mid length/long tube headers with the Radix.
Old Feb 8, 2005 | 03:13 PM
OCBC's Avatar
Losing boost makes logical sense. But is it enough of a loss to worry about? Maybe not?
Now all I got to do is get a freakin Radix already....................
Old Feb 8, 2005 | 03:28 PM
you might loose some boost but you are not loosing power. It is just making it more efficient.
Old Feb 8, 2005 | 03:58 PM
Mangled03gmc's Avatar
Baltimore Whore
absolutly
Old Feb 8, 2005 | 05:05 PM
KySilverado's Avatar
Thanks
I gained 1/2 second reduction in quarter mile times and lost no boost with my Dynatech, Y pipe and cat install.
Old Feb 8, 2005 | 05:19 PM
Less restriction means you can possibly gain .5psi. Less restriction is a good thing when your cramming all that air in the engine...
Velocity1
Oct 12, 2015 10:39 PM
Superman09
Sep 25, 2015 05:55 AM
bagged7104SS
Sep 24, 2015 08:42 PM
5.3lSilverado
Sep 20, 2015 06:48 PM
