headers going on tonight !!!!
Old Jul 11, 2007 | 07:52 PM
circusboy's Avatar
Default headers going on tonight !!!!
they're here !!!! they're here !!!! they're here !!!!
got pacesetter LT's and pacesetter ORY today. The truck is cooling off right now. I do have one question. do you have to remove the trans cross member to get the y-pipe out on the 07 NNBS?
Old Jul 11, 2007 | 07:55 PM
Phantom's Avatar
11 Second Club
probably
Old Jul 11, 2007 | 08:09 PM
xlcooplx's Avatar
nope, break out the handy sawzall!!! otherwise, probably so. i couldnt get the manifolds to separate from my stock y-pipe so i ended up cutting those off as well. hopefully this will be of no problem to you.
Old Jul 11, 2007 | 08:11 PM
Phantom's Avatar
11 Second Club
i would take the cross member off that way you can keep your y-pipe in one piece...ya know just in case
Old Jul 11, 2007 | 08:14 PM
circusboy's Avatar
Thanks fellers. This should be fun as one person job. off I go
Old Jul 11, 2007 | 08:17 PM
Phantom's Avatar
11 Second Club
took me maybe 3 hours by myself....and i lose tools alot
Old Jul 11, 2007 | 08:46 PM
xlcooplx's Avatar
fyi, i had to put the passenger header in from the bottom. couldnt get enough clearance by the frame from the top.
Old Jul 11, 2007 | 08:47 PM
blue_04's Avatar
If you want the y-pipe out in one piece you will have to drop the crossmember. It's not hard, just make sure you've got something holding the tranny in place.
EDIT: Just re-read first post, didn't see that it was a NNBS So I really don't know, but it can't be that much different.
Old Jul 11, 2007 | 11:54 PM
circusboy's Avatar
man i miss my tools. they are in a POD in a new orleans warehouse. all hand tools tonight. I could not get the front o2 sensor off on the passanger side, so i unpluged it. I did drop the cross member. that was the easy part. the swival is the greatest tool ever invented. i had to borrow one from the neighbor, lol. I thought the cat nuts would come off easy because the truck only has 8000 miles. I thought wrong, lol.
for toight I did:
oil change. put in Royal purple 5w-30, mobile 1 extended performance filter, removed o2 sensor, removed cross member and removed y-pipe. I should be able to get back on this project and finish it friday night.
Thanks for all the help fellers.
Old Jul 12, 2007 | 08:51 AM
xlcooplx's Avatar
eh, guess i missed that it was a NNBS as well
