headers are on...
Old Mar 6, 2009 | 11:16 AM
texasbullseye89's Avatar
Thanks for the ideas guys. Starting to look into it right now
Old Mar 6, 2009 | 11:29 AM
TX Tahoe Z71's Avatar
What muffler do you have on there?
Old Mar 6, 2009 | 01:23 PM
right now? a chokemaster single chamber. causes headaches at idle. let alone WOT
Old Mar 6, 2009 | 02:25 PM
dug's Avatar
dug
Banned
Originally Posted by texasbullseye89
coated. fits like a glove. i think i posted in a thread you started already..
nope, but thanks for your input
Old Mar 6, 2009 | 03:22 PM
silver-mod-o's Avatar
Hunt&Fisherator
I think the truck sounds pretty good personally LOL...
Id stick two short bullets in there, and run a long case Magnaflow, and for goodness sakes, dump it behind the axle... that should cover all your problems.
Have you ever heard spintech mufflers??? they sound NICE...
Old Mar 6, 2009 | 06:26 PM
ThrottleHappy7's Avatar
Different setup entirely, but I knew a guy that had a '95 Z28 with Bullets...
I like the ideas from fredkj3 and Modern_Muscle.
Old Mar 6, 2009 | 10:50 PM
only reason you think that is cause it sounds better than the s-turd.
Old Mar 6, 2009 | 11:46 PM
my cats are Flowmonster 3" ceramics...with one of them on the end of the pacesetter ORY with no mufflers and about 6' of pipe attached to it (I cut off the muffler & sold it, and mine ended up going backorder) to try to quiet down my longtubes, and it worked. It quieted them down.
But when I put the dual 3" into the 4", with a cat on each 3" it was loud as fawk, just as loud as open headers for some reason (with no muffler, and was TONS louder than the single cat on the end of the ory)...
right now mine is perfect. I cant be more satisfied, until I get my tip on. Mostly homemade.
Old Mar 12, 2009 | 09:45 PM
buster628's Avatar
if i buy a set of pacesetters would they just bolt right on to where my cats are located or would i have to get a y pipe i am running a magnaflow system from the cats back thanks in advance
Old Mar 13, 2009 | 12:10 AM
dug's Avatar
dug
Banned
When you run pacesetter headers you have to run their ypipe. The ypipe bolts right up to the catback.
