headers?
Old Jan 27, 2005 | 08:17 PM
TWANKYDEUCE's Avatar
Default headers?
I want to get some headers and have them installed but no one around here (new orlean)will intall them. Anyway, what involved in installing headers, I have absolutely no clue. Would I have to pull the engine? Take off the front suspension? something about the o2 sensors?
Thanks in advance
Old Jan 27, 2005 | 08:34 PM
I had somebody tell me 200ish give or take some on ASM Longtube installation. I would reccomend the ASMs, TOGs or Thorleys, don't waste your time with shorty headers. You won't have to remove the engine just have some cutting/welding done to the exhaust after you put the headers on. The 02 sensors should still work fine I beleive, if i'm wrong there someone that has them will chime in i'm sure.
Old Jan 28, 2005 | 09:51 AM
nativetexan's Avatar
13 Second Truck Club
Man, You may want to check out Futral Motorsports ---------->>> from the sponsors links. I hear great thing about those guys and they are just upe the road in Baton Rouge.
Old Feb 6, 2005 | 11:31 AM
bravo one's Avatar
I'd think twice about the headers. Just had hookers put on my z71 and it has been a nightmare. The ******** that did it really fucked up my truck. If they don't get installed properly you are screwed, find the best exhaust guy its well worth the extra money in the long run.
Old Feb 7, 2005 | 02:16 AM
bluecajun5.3's Avatar
11 Second Truck Club
if you have a lift, it will be real easy. i put on my shorties in 2 hrs.
Old Feb 7, 2005 | 05:21 AM
Gordy M's Avatar
A friend and myself put my Thorley's on in less than 3 hrs, including changing the spark plugs. The hardest part was changing the #7 plug.
You will need a sawsall type of metal cutter, welder, standard sockets and swivel. Remember to remove the front O2 sensors. After welding the flange on the cats, one side was slightly off center and required a prybar to align. The Thorley's were an easy fit and I had no problems getting them in from the bottom. After they are on a week, retorque all the bolts and that it.
Old Feb 7, 2005 | 05:49 AM
one03sierra's Avatar
Formerly one92rs
Talking
if you want headers and to have them installed then go to futural. they will sell and install the headers for you. if not then you can do it yourself as well.
Old Feb 7, 2005 | 12:41 PM
Jason 98 TA's Avatar
FormerVendor
You might check out our new pacesetter header options! I have pics in the intro post
Old Feb 7, 2005 | 12:57 PM
lifted99's Avatar
The header install on a truck is easy. The f-body install is a little more involved, but I wouldn't worry much about the truck install. Just get them in, and get it to a good muffler shop to have them button up the rest of your exhaust.
Old Feb 7, 2005 | 02:12 PM
Call GT Automotive
