Header wrap
Old Sep 5, 2013 | 09:03 AM
BigDaddy0381's Avatar
Default Header wrap
whats the though on warping headers to keep under the hood cooler? maybe some valve train clacking down?
Old Sep 5, 2013 | 07:09 PM
Blackpanther99's Avatar
Wrapping headers also helps on maintaining heat inside the headers while allowing the exhaust heat to flow fast through the piping.
Old Sep 5, 2013 | 07:17 PM
Ricksilvy's Avatar
Was told that wrapping the headers can wear them out fast.
Any validation in this? What about wrapping ceramic coated headers?
Old Sep 5, 2013 | 07:39 PM
silverado6.2's Avatar
Most companies will not warranty headers that have been wrapped. It does help with under hood temps but I guess the tubing would naturally run a lot hotter.
Old Sep 5, 2013 | 08:32 PM
what make the tubing wear out faster when wrapped? more heat not being let out of header? would what heat it would keep out worth the work?
Old Sep 5, 2013 | 10:55 PM
Whitecrewcab's Avatar
I had to wrap the headers on my BBC 71 Camaro so it would quit melting starters lol. It doesn't get driven very much though, so I'm not sure of the damage to the headers yet?
Old Sep 6, 2013 | 03:59 AM
Did it keep.under the hood in general cooler?
Old Sep 6, 2013 | 06:13 AM
Suburbazine's Avatar
Wrapping the headers will cause molecular structure changes when they get very hot. Eventually the wrapping will be ONLY thing holding the piping together, should you pull it off you will have holes emerge in the piping due to aggressive corrosion.
Old Sep 6, 2013 | 07:18 AM
okay, Thanks. if I bought a new set of headers and warped them. I wounder what the life of them would be? 2 years 5 maybe? I'm still 50/50 on doing this.
Old Sep 6, 2013 | 09:50 AM
Well the mini starter only lasted 3 months the first time and 1500 miles. Since I wrapped the headers, it's been on there over a year and I've put about 6000 miles on it. It definitely helps with the heat control.
