Header question
Old Feb 23, 2006 | 11:55 AM
Dave68RT's Avatar
Default Header question
hey guys, if i bought pacesetter long tubes and wanted to keep my stock cats, will that work? or will they need to weld a new y-pipe?
thanks
Old Feb 23, 2006 | 01:08 PM
ap2002's Avatar
I would say weld a new y pipe?? but why keep the cats??? you dont know what you are missing out on... all you got to do is have your tuner delete the rear O2's....
Old Feb 23, 2006 | 02:53 PM
Dave68RT's Avatar
my parents are the reason..I kind of want to keep them but this is deciding whether i get them or not
Old Feb 23, 2006 | 02:59 PM
BLACKND's Avatar
I had thought about this too. When I get my new project would like to do this too, but I will be going true duals. Was thinking that getting a set of cat pipes off of an HD truck and modify them to work with the pacesetters.
Old Feb 23, 2006 | 05:21 PM
superchevy00's Avatar
ya, I was wondering too if you could run longtubes and cats. (keep it street legal)
Old Feb 23, 2006 | 05:34 PM
joehawkz71's Avatar
ok i have been looking at LT headers now for some time....i was looking at the pacesetters.. i like them cuase they are cheap and everyone says that they likes theres...but i was also wondering about the coating on them..... Is it a ceramic coat? and if i was to get them would they rust ( keep in mind i live in minnesota and theres lots of salt on the roads )
other wise is there anyone other then stainless works that sells S.S Lt headers?
any help would be great!!
Old Feb 23, 2006 | 05:35 PM
LS1TRUCKGUY's Avatar
Yes You Can Run Cats With The L/t's. The Random Technologies Cats Are Nice, But Are About $150.00 A Piece. It Is A Pretty Tight Squeeze Between The Collector And The Transmission Crossmember, But They Will Fit. Your Best Bet Is To Have A Custom Y Pipe Bent.
Old Feb 23, 2006 | 10:01 PM
Dave68RT's Avatar
yes they're coated.
so what do yall think? will they need to modify a new y-pipe with cats..
honestly i dont want corsa w/ LT's and ORY
Old Feb 23, 2006 | 10:08 PM
onebadrubi's Avatar
I have pacesetter into 2.5" pipe and the cats were in the stock location for a month or so...then took them off. My pipe then runs into a xpipe and then into two flowmaster 40 series dumped before the axle. The sound is MUCH better and performance is better without cats. It isnt much louder under 2500rpms without cats. Can still get around the neighborhoods late at night without even being herd pretty much. But if you get on it it will get kinda loud.
Old Feb 23, 2006 | 10:09 PM
v8
17,16,15,14,13,12,11 Drvr
you will have to have a custom Y-Pipe bent and it will work just fine with the stock cats, I didn't feel a diff. when i had cats or without them, good luck.
