Header install questions
Old Jun 19, 2008 | 12:04 AM
  #21
05cc's Avatar
get a sawzall and cut the stock y-pipe out if you are putting a ORY on. that way you wont have to remove the tranny crossmember. get 2 3"-3.5" band clamps. they will connect the headers to the ORY and that way you can remove the exhaust easily if you have too later. have a friend help you so he can hand you the headers from under the truck and you can arrange them where they need to be. and before you remove the old manifolds, take out the oil dipstick first and than the oil dipstick tube. it will just pop out from the pan. i removed the tube w/ the stick still in and when i went to put it back in, the stick must have gotten hung up on some internals and it was causing a slapping sound. it took a while to figure out what it was. oh and if your friend is kind enough to help you unbolt the stockers and bolt the new headers on, make sure you get on the passenger side first. they are alot easier to get to than on the drivers side.
Old Jun 19, 2008 | 01:47 AM
  #22
D_reks{5.3}'s Avatar
wow thanks for the write up..any special tools out of the ordinary that i might need? also how hard is it to install a vette servo? i wanna do it the same time i do the headers if its easy enough to do.
Old Jun 19, 2008 | 02:15 AM
  #23
05cc's Avatar
no special tools. i think i used a 15mm, 13mm, spark plug socket and wratchet extention and an adjustable wrench in one or two spots. probably on the o2 sensors. if you have air tools than it will go by 4x as fast. are you going to weld up the y pipe or just use the stocker? a vette servo install is pretty simple and will be even easier with the y pipe removed, so doing it when you do your headers will be a good time. i think there is a link to a write up in the powertrain section of the forums. no special tools for the servo install either.
Old Jun 19, 2008 | 11:21 AM
  #24
ok cool and ya we will be using air tools..and as far as the y pipe all that..i am takin it down tomorrow for the exhaust im just installing the headers today...the servo didnt seem like it would be to hard.
Old Jun 19, 2008 | 04:34 PM
  #25
sonoma43's Avatar
It sounds so easy....but it never seems to go as smoothly as it should, or at least for me nothing ever goes smoothly when I do my lt's this weekend im sure a bolt or 2 will most likely break, something wont fit right....SOMETHING is bound to go wrong. thinkin about it now it's kinda funny but when im under the truck in 85 deg. weather I wont be laughing. an extra case of cold one's outta do the trick though!
Old Jun 19, 2008 | 04:37 PM
  #26
Parke10's Avatar
i wish it was anice 85 outside when i get under her 2night, but nah its gonna be 98 to 103 ish while im under it.
Old Jun 19, 2008 | 07:10 PM
  #27
we have on thing in common with him..there will be some cold ones
zblee
Aug 3, 2015 03:45 AM
sauldgold
Jul 23, 2015 02:15 PM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
N/ALS1
11
Jul 13, 2015 10:56 PM
