Header install on my Escalade pics/video.
Old Mar 9, 2009 | 04:39 PM
SUX2BU's Avatar
11.0 Moderator
Default Header install on my Escalade pics/video.
Video's are up loading now. It's taking forever.
Install wasn't bad. All i really had to do was drop the tranny cross member and remove the engine covers. The headers did get scratched up a bit having to snake them up from underneath but it wasn't too bad. The driver side is a little close to the front DS but it had a good 1/2" clearance. Only thing is that no one makes replacement pipes to bolt up to your stock cat back. Everyone sels a Y pipe but the 6.0 motor has two individual pipes going back to the muffler. so i rigged up a temporary set up untill i decide what the rest of my exhaust is going to consist of.
OBX makes a whole SS kit with the two individual pipes but theyre headers look ugly (design wise) and the collectors are only 2.5". Pacesetters are 3" collectors. Also Pacesetters are ceramic coated and will keep under hood temps down better than SS headers. BUT if you live up north i would recommend SS headers or if your big $$ coated SS headers.
It is actually VERY quiet. Only a slightly deeper rumble than before at idle. Inside you can not even tell a difference, it is still extremely quiet. Under the hood is a little noisier but the average person wouldn't notice it.
I heard like something was rubbing at first start up but then it went away.
Driving around: regular off the light driving feels the same but i do feel like it needs less pedal to stay cruising. WOT, down low feels the same mid and high end feel a lot smoother and like the truck is actually lighter. Picks up very good. You can barely hear the exhaust at all, you can actually hear the intake over the exhaust if anything. Although i did romp on it next to a wall and it sounded
Any other questions, just ask.
Old Mar 9, 2009 | 04:44 PM
SUX2BU's Avatar
11.0 Moderator
Old Mar 9, 2009 | 04:47 PM
GMCtrk's Avatar
Sounds good. Glad you like the setup. My opinion on the matter is that Paces are garbage compared to the OBX, having handled both. My issues with the OBX stemmed from the fact that I had a crossmember bolt in backwards thus contacting the Y pipe. Idiot me.
How is that ebay CAI working for you? I've had my eye on that one. I've heard the filter is garbage though.
Old Mar 9, 2009 | 04:50 PM
sonoma43's Avatar
Everything look's good!
I think the pace's are very nice for the money, They fit very well and perform like any other LT would!
Whippled 496's Avatar
Install looks good!
Not sure about jacking it up by the tranny pan though..... Unless that was just for holding while the Xmember was out.
My findings are very similar to yours, even the rubbing part.
Old Mar 9, 2009 | 04:52 PM
GMCtrk's Avatar
Originally Posted by Whippled 496
Install looks good!
Pretty sure he's just holding the transmission up with the crossmember out.
Old Mar 9, 2009 | 05:52 PM
SUX2BU's Avatar
11.0 Moderator
Never handled OBX, but the driver side looked funny, plus i live in Texas so salt isn't a problem but heat is and i wanted cooler under hood temps so i went coated. I've installed maybe 70 sets of headers from 10 different companies and most are pretty equal. Only thing i don't like about Pacesetters are the AIR and EGR tube bolt holes aren't threaded but they are not used in my application. There was an EGR tube on the pass side so i just welded that shut.
The Ebay CAI is awesome! The filter is very crappy as far as filtering stuff, but that only means it flows good. So if you drive your truck as a daily or in sandy dirty conditions i would suggest swapping it out. I only drive my truck 2-3 times a week at most so i left it in.
Old Mar 9, 2009 | 05:54 PM
GMCtrk's Avatar
Well, I think I'll get that CAI though, but the place that was selling it for $61 shipped doesn't have it anymore
Old Mar 10, 2009 | 11:45 PM
idahoblkss's Avatar
nice set up!! looks good!
Old Mar 11, 2009 | 10:42 PM
SUX2BU's Avatar
11.0 Moderator
Here are the videos sorry took so long.
http://videos.streetfire.net/video/E...dle_640668.htm
http://videos.streetfire.net/video/E...dle_640667.htm
