Header install -
Old Mar 10, 2016 | 03:40 PM
cj847's Avatar
Default Header install -
I have a 2002 SCSB and I'm trying to install headers and I can't get them in. Driver's side I can't get in from top or bottom (remote jump electrical is moved out of the way). Do I have to pull the brake booster to get them in??
Passenger side I got in from the bottom but they are bound between the frame rail and block. I read something about a bad motor mount could cause this, so I put a jack under the motor and jacked it up, but it still won't fit.
This can't be that hard. What am I doing wrong?
Old Mar 10, 2016 | 03:56 PM
What brand an length of header?
Old Mar 10, 2016 | 04:03 PM
Wolftrk99's Avatar
Take the steering shaft loose on the driver side, do you have anyone helping you headers go in easier from bottom fyi
Old Mar 10, 2016 | 06:09 PM
Jake75's Avatar
try turning the steering wheel to either side before u take it loose too
Old Mar 10, 2016 | 08:52 PM
cj847's Avatar
thanks for the comments. I'll be working on it again sunday and will disconnect the steering column. Will post pics if I'm still a fail.
Old Mar 10, 2016 | 08:56 PM
LARRY01Z28's Avatar
mark the steering column before you loosen it. also if you have the cross brace bars going from the frame to the cross member it helps to loosen these up and spin them out of the way.
Old Mar 11, 2016 | 08:24 AM
parks450's Avatar
Just need to take the bolt out of the steering shaft about half way up it. No need to remove it off the steering
Old Mar 11, 2016 | 08:42 AM
Wolftrk99's Avatar
If youre two wheel drive the cross braces are more than likely whats hanging you up.... Word of advice... wiggle shove walk away for a few minutes come back and wiggek adb shove again and they will probably drop in... At least how it usually works for me....
Old Mar 11, 2016 | 10:14 AM
ss4chad's Avatar
12 Second Club
I take the steering bolt out and separate the two pieces (after I have marked them) and then take out the cross braces. I like the room it gives me plus I can hang the header on a something to keep it up while I crawl out from under the truck and go back to the engine bay and grab it and get a bolt started. Then I can fish in a gasket and bam!
Chad
Old Mar 11, 2016 | 10:41 AM
madmann26's Avatar
Like Wolf said, taking the bolt out of the steering shaft.
The driver side you have to put in from the bottom, the passenger side falls in from the top.
