Header Install
Old Oct 4, 2015 | 11:07 PM
Wolftrk99's Avatar
I got so confused with injectors, while building mine, i ended up getting a full take off intake and put it on abd turned out ended up with 40-42 lb flexfuel, got lucky
Old Oct 8, 2015 | 08:49 PM
2000silvrx81's Avatar
They're here
Old Oct 8, 2015 | 09:05 PM
Wolftrk99's Avatar
Those are seeeexxxxyyyy!!! My girl would have a fit if i laid mine out in my house like that, lol!!!
Old Oct 8, 2015 | 11:25 PM
ezdaar's Avatar
Coat and wrap those shiny things. the valve noise is .. Loud..
Hells yea! You got the latest revision, passenger 02 is clocked completely diff..
Looking at that pic, my O2 is at the 1 oclock position.
Post on clearance issues, if you have any.
You have the spikes in the collector?
Old Oct 9, 2015 | 07:56 AM
Fast355's Avatar
Originally Posted by 2000silvrx81
I ordered the Speed Engineering 1 3/4" headers with ORY. Checked this morning with a stubby screwdriver. Bolt is definitely broken off flush with the cylinder head.... looks like I'll be pulling out my welder for this one
Good luck with it. The last 5.3 I messed with I had to Helicoil 3 bolts in one head. I have about 6 LS heads kicking around the shop and nearly all have bolts broken flush with the head. I got lucky on the 8.1. Every manifold stud except 1 pullled out with the nut and I put some CRC freezeoff on the one and worked it out.
Old Oct 9, 2015 | 11:09 PM
Only 1 broken bolt on the drivers rear, going to weld a nut on it in the morning and get it out. Everything else worked like a champ. Spikes in the collector, yes. Hoping fitment is good. I noticed the pipes are extremely loose on the slip fit so I'll have to peck them down a little to get it it clamp down correctly.
Old Oct 10, 2015 | 07:45 AM
Klein7's Avatar
Thats the way it goes sometimes! Next thing will be a BTR Stage 3 truck cam, and I'll have to order injectors being my truck is a 99. Still have no clue what injectors to get though.
have the speed engineering lt's as well.. rather nice for their pricepoint
do you mind explaining why you need injectors? Have a 99 as well and looking at the btr stage 3 too.. and well, connect the dots
edit: nvm, it's early and I didn't gewgle before posting.. found it here
https://www.performancetrucks.net/fo...verado-487974/
Old Oct 10, 2015 | 07:34 PM
Fast355's Avatar
The 99s injectors are MAXED OUT on a stock engine. After 99 GM had a mild cam change, better PCM tune, larger injectors and more power from the same engine.
Old Oct 10, 2015 | 07:56 PM
Wolftrk99's Avatar
Dont remember exactly but the 99 injectors were something like 32lbhr or some stupid crap.... Barely enough for the 5.3/6.0
Old Oct 10, 2015 | 08:33 PM
Fast355's Avatar
19 lb/hr seems to stick out in my mind.
