header install?
Old May 11, 2005 | 11:19 AM
02chevyracing's Avatar
14 Second Truck Club
Default header install?
im installing the edelbrock headers tomarrow, and i was wondering do you need to buy new headers gaskets or will the stock gakets still work? also I heard the just bolt on, but i have also heard there is some welding they look like they just bolt straight on, anyone? thanks Gene
Old May 11, 2005 | 11:46 AM
Eye-P's Avatar
i just installed these on my 2004. I reused the stock gaskets. One side leaks a bit until it warms up, while the other side is fine.
I am going to replace the leaky side gasket with a new stock one. I think they are less than $10.
Reuse the stock collector gaskets also.
There is no welding required- this is a direct bolt in.
Old May 11, 2005 | 11:49 AM
Mine came with new gaskets. They just bolted right on. It is a little easier if you remove the steering shaft, at least it was for me.
Just FYI- dont expect much of a performance gain. I used mine because I got them ulta cheap and new, but there is little difference.
Old May 11, 2005 | 02:10 PM
They bolt right on and you don't have to remove the steering column. One header has to go in from the bottom of the truck. I'm pretty sure it's the left header. You can reuse the stock gaskets, but I replaced mine. The only problem I have is a small exhaust leak where the header mounts to the cat on the left side. With the exception of that, I'm happy with what I got. Sounds cool too.
Old May 11, 2005 | 03:17 PM
ap2002's Avatar
Replace With New Gaskets While You Are At It......
Old May 11, 2005 | 03:23 PM
Gran Patron's Avatar
Yeah Gene buy new gaskets, It'll be better. Are you going to install them with John?
Old May 11, 2005 | 03:45 PM
I never said you had to remove it, I just said it was easier if you did. It is only 2 bolts to remove the shaft(not column) and you can get the left side in super easy and get all the bolts right there. I didnt even raise my truck to do mine, took very little time. Just offereing pointers from my experience.
Also, Am I the only one that got gaskets in the box? I dont think they were as good as the OE ones, but they are working fine and I still have no leaks.
Old May 11, 2005 | 05:29 PM
ap2002's Avatar
i used the gaskets in the box and they both leaked shortly after.... so I bought the oem ones.... and have not had a problem...
Old May 11, 2005 | 07:06 PM
z7199's Avatar
Yep early in the morning going to get started around 7:00 a.m. Chris is going to help to.
Old May 12, 2005 | 11:40 AM
well i dont expect to gain to much, but i bet its worth the 70 bucks i paid. plus ill problaly like the look. Gene
