header install?
14 Second Truck Club
im installing the edelbrock headers tomarrow, and i was wondering do you need to buy new headers gaskets or will the stock gakets still work? also I heard the just bolt on, but i have also heard there is some welding they look like they just bolt straight on, anyone? thanks Gene
i just installed these on my 2004. I reused the stock gaskets. One side leaks a bit until it warms up, while the other side is fine.
I am going to replace the leaky side gasket with a new stock one. I think they are less than $10.
Reuse the stock collector gaskets also.
There is no welding required- this is a direct bolt in.
Mine came with new gaskets. They just bolted right on. It is a little easier if you remove the steering shaft, at least it was for me.
Just FYI- dont expect much of a performance gain. I used mine because I got them ulta cheap and new, but there is little difference.
They bolt right on and you don't have to remove the steering column. One header has to go in from the bottom of the truck. I'm pretty sure it's the left header. You can reuse the stock gaskets, but I replaced mine. The only problem I have is a small exhaust leak where the header mounts to the cat on the left side. With the exception of that, I'm happy with what I got. Sounds cool too.
Also, Am I the only one that got gaskets in the box? I dont think they were as good as the OE ones, but they are working fine and I still have no leaks.
Originally Posted by runin9s
Yeah Gene buy new gaskets, It'll be better. Are you going to install them with John?
