Header Instal from hell....
Old Jan 19, 2010 | 07:58 PM
SLOXCAB's Avatar
i was told this was a common issue so i soaked my manifold bolts everyday for a week and they all came out like butter but it sucks to hear this happen to you
Old Jan 19, 2010 | 08:03 PM
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by viciousknid
I have one bolt that wouldn't go all the way in and is sticking out like 1/3 of the way. No leaks
I'll get around to making sure the threads are good some time.
You're lucky Josh, I've seen headers leak that were perfectly torqued, with clean surfaces and new gaskets...and all bolts installed. Granted the GM steel gaskets are forgiving, but loose or missing hardware on the header flange usually isn't...
GMCtrk's Avatar
Soaking it wont do anything. The bolts are already snapped off before you even touch them.
Old Jan 19, 2010 | 08:05 PM
SLOXCAB's Avatar
i did not know that i just heard they break off really easy when you try to take them out but i guess i just got lucky on mine
Old Jan 19, 2010 | 08:09 PM
GMCtrk's Avatar
I think it's just completely dependent on how many hot/cold cycles the bolt has gone thru (i.e. the age/mileage)
Old Jan 19, 2010 | 08:12 PM
Mangled03gmc's Avatar
Baltimore Whore
I think that is a good guess by far... Brand new trucks have had them break, along with old ones. It is the nature of the beast in this case.. Some will some won't...
SILVERADO11's Avatar
is there a better bolt/stud that would help this ?
Old Jan 19, 2010 | 08:13 PM
SLOXCAB's Avatar
oh ok then i guess i got really lucky 2004 with 88k on them
Old Jan 19, 2010 | 08:15 PM
03chevyroyce's Avatar
mine did it too
i said screw it and put the headers on anyways
BTW, PB blaster is your friend
Old Jan 19, 2010 | 08:19 PM
Baltimore Whore
Yah the trick is lock washers with anti seize. The main reason it does this is the difference in the metals, aluminum is extremely corrosive..
