Header A.I.R.
Old Nov 24, 2003 | 10:56 AM
z7199's Avatar
Default Header A.I.R.
What does it mean on headers W/ A.I.R. or W/O A.I.R. how do you know if you have A.I.R. or not. Does it mean you have a smog pump if so I havent seen a 5.3L with A.I.R. so why would they put that on there?
Old Nov 24, 2003 | 11:36 AM
Yep, it's a smog pump. If you have AIR, there is a stainless mesh covered tube hooked up on each of you exahust manifolds, my California truck came with it. Why is it there, emissions.
Jim
Old Nov 24, 2003 | 12:40 PM
FILE's Avatar
Talk about being strick in Cali.....
Old Nov 24, 2003 | 02:27 PM
z7199's Avatar
Jim
I is this diffrent from the EGR or is it the same thing? I only have a pipe on one side /passenger I dont see any smog pump though.
Old Nov 24, 2003 | 09:12 PM
The AIR is different from the EGR, the EGR is one pipe that goes into the intake manifold just behind the TB on the passenger side. There are two AIR tubes, one in each exhaust manifold and the pump is on the passenger side up by the hood hinge. I was wrong about the pipes having a mesh cover, mine don't. Sounds like you may not have it, not all states require it.
Jim
Velocity1
Oct 12, 2015 10:39 PM
Superman09
Sep 25, 2015 05:55 AM
dirt track racer 81
Sep 21, 2015 06:44 PM
5.3lSilverado
Sep 20, 2015 06:48 PM
