Header Collectors replacement??? Do V-Bands work?
Old Dec 3, 2008 | 09:06 AM
blue2003ls's Avatar
Default Header Collectors replacement??? Do V-Bands work?
I have a leaky collector that is driving me nuts. I don't care for the Bassani collectors so I am thinking about replacing them with a set of 2.5" v-bands. I have seen a few people do the same but haven't heard if they hold up to the test of time. Any input would be great.
Old Dec 3, 2008 | 09:54 AM
BlackGMC's Avatar
Resident Retard
I have had mine on for about 6 months and they are doing great... Soooo much easier to get on and off... I like to put a very thin coating of High temp RTV on both sides of the mating flanges, then put on the V-band and it works great!!!
Old Dec 3, 2008 | 10:24 AM
OLD BULL's Avatar
v-bands or stack breakers work great
Old Dec 3, 2008 | 12:00 PM
GMCtrk's Avatar
Wrap a couple layers of aluminum foil over the joint. Then crank down a stepped band clamp over it. I learned this trick from a member here and it works! Much cheaper and easier than V bands too. Mind you, the joint I did it on wasn't a snug fit either so it does seal up nicely.
Old Dec 3, 2008 | 02:28 PM
blue2003ls's Avatar
That may be a good trick for right now to keep it sealed for now. I just hate trying to get a wrench on the crappy flanges that come with the headers so I think replacement is inevitable.
How much are they typically and where's a good place to buy them. They are pricey at Summit and the ebay finds look a little questionable.
Old Dec 3, 2008 | 02:35 PM
BlackGMC's Avatar
Resident Retard
This is where I got mine...
http://store.racing-solutions.org/vbands.html
I have also had good luck doubling up the 3-Bolt flanges to make them twice as thick. I just run a bead around the pipe inside and out, then weld another flange on top of that... But I love my V-bands!!
Old Dec 3, 2008 | 05:33 PM
GMCtrk's Avatar
Torctite 3" stepped band clamp. They work awesome. They are about $12 each and you can get them off ebay. I just order 2 more off ebay because my local NAPA only had 1 and wanted $8 a piece to ship them in from Chicago.
zblee
Aug 3, 2015 03:45 AM
sauldgold
Jul 23, 2015 02:15 PM
Ketis
Jul 23, 2015 12:37 PM
atxlt
Jul 20, 2015 11:06 PM
