Head Swap Q
Old Dec 21, 2006 | 08:49 AM
Silver-Dollar's Avatar
Default Head Swap Q
What all needs to be replaced with head swap? I know head gaskets, exhaust gaskets, and head bolts. How about intake gasket, intake bolts, and header bolts? Is there anything else?
Old Dec 21, 2006 | 09:51 AM
tdrumm's Avatar
You've got it covered. I reused my intake gaskets and bolts, and header bolts.
Old Dec 21, 2006 | 09:54 AM
quicksilverado's Avatar
You can reuse the exhaust gaskets too.
Old Dec 21, 2006 | 10:32 AM
you're going to need coolant and probably will want to change the oil shortly after. you might look into some scotch bright pads if you want to clean the carbon build up off. you will also want some carb cleaner to clean your reused stuff
Old Dec 21, 2006 | 11:55 AM
Thanks. Now I just need to get the cash for the heads, cams, and pushrods. I was thinking along the lines of 5.3l 3.78 bore heads from WCCH and cam would be a 220r on a 112. Or do you think a 224 would be better? Mods are as listed in sig. My only concern in spinning the motor up to or past 6500. I would like to keep the shift point around 6200 and make peak hp at 5900 or 6000 rpm.
Old Dec 21, 2006 | 12:14 PM
tdrumm's Avatar
You'll end up with almost the same combo as me. I'm running a set of WCCH Stage 1 heads with a VHP 210/218 112 cam. I have a Comp 220/218 111 ready to go in as soon as I get my Yank TT3000 and 4.10s installed. The final piece will be a LS6 intake which I am slowy piecing together as funds allow.
Old Dec 22, 2006 | 12:50 PM
budhayes3's Avatar
PT's Slowest Truck
Can't wait to take a ride in your truck when it's all done I guess we'll be doing another TTP dyno day in the future
OHsixLS3
Dec 27, 2016 09:30 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
Ketis
Jul 23, 2015 12:37 PM
Aboss
Jul 9, 2015 10:28 AM
NuckenFuts
Jul 9, 2015 08:45 AM
