head swap
Old Jul 12, 2013 | 11:37 PM
hsiriyob's Avatar
Originally Posted by batboy
Yep, breaker bar and socket on the pulley bolt is the easiest way. I have bumped the engine over with the starter too if the plug wires are off. The motor will turn over easier if the spark plugs are out (no compression then).
Do a quick search on LS1tech and I think you'll see the LS9 gaskets are the ones to use for boast. Basically, a LS9 is a supercharged LS3. The LS9 gaskets have more layers and supposedly seal better under boost conditions. I'd bet Thompson meant LS9 gaskets when he told you.
If you only have 2k miles, then you don't need anything else other than mybe new valve seals, switch the springs over, new gaskets, and anti-freeze. I always like to change oil/filter after a head swap too.
Im currently running the ls9 gasket with my prc heads. he recomended the ls3 gasket over going the ls9 route because of the fifty dollar diff. I did question him because ive heard good things about the ls9 but he swears by the ls3. there are some high hp boosted ls3's out there so either way i should be good.
OHsixLS3
Dec 27, 2016 09:30 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
Ketis
Jul 23, 2015 12:37 PM
Aboss
Jul 9, 2015 10:28 AM
NuckenFuts
Jul 9, 2015 08:45 AM
