Which head studs?
Old Nov 12, 2009 | 09:51 PM
1BADAZZSS's Avatar
Default Which head studs?
I have a 06' LQ4 that I am needing some ARP head studs and I am trying to figure out which ones to get. One kit has 4 shorter bolts then the rest. Any help? Thanks Thomas
Old Nov 12, 2009 | 10:19 PM
CODE4LS1's Avatar
The kit with 4 shorter head studs are early LS1 style. I think your 6.0 has all he same size head studs.
Old Nov 12, 2009 | 10:30 PM
aaronmc's Avatar
03 and earlier have the 4 shorter bolts, later models are the same length.
Old Nov 12, 2009 | 10:35 PM
1BADAZZSS's Avatar
good deal, wanted to make sure before I spent the dough. Thanks guys
Old Nov 14, 2009 | 08:44 AM
Rick_Vor's Avatar
If you haven't already picked them up, go with the 12pt nuts ARP# 234-4317.
http://www.sdparts.com/product/ARP23...LS12004Up.aspx
Rick
Old Nov 14, 2009 | 08:47 AM
ChevyTruck's Avatar
something else
Rick
Why do you suggest to get them Rick? I am only asking because I will be in the market for head bolts, head studs soon also and any information is good to me.
Old Nov 14, 2009 | 02:20 PM
Rick_Vor's Avatar
I know it's a $20 premium for the 12pts but that one time when getting a breaker bar into position because your running 6pts nuts makes it all worth it. Another benifit is the 12pt socket is a smaller diameter which helps when trying to squeeze into tight quarters. A 12pt socket has more clamping sirface than a6pt so there is less chance of stripping a nut.
I've read that at high torque readings (something like 200+), the 12pt spreads the load out more evenly than a 6pt. I don't think that is relevant at our torque levels. ARP actually added the 12pt option back in the day for valve spring clearance on old school small blocks. Large diameter valve springs would block access to a 6pt nut.
Regarding the studs verses bolts, this is clearler than anything I can write:
HEAD STUDS vs. BOLTS...
A TECHNICAL DISCUSSION
ARP’s factory Tech Representatives are often asked which
is better, cylinder head studs or bolts. The answer, invariably,
depends on the installation. On many street-driven vehicles,
where master cylinders and other items protrude into the engine
compartment, it’s probably necessary to use head bolts so that
the cylinder heads can be removed with the engine in the car.
For most applications, however, studs are recommended.
And for good reason. Using studs will make it much easier to
assemble an engine (especially a racing powerplant which must
be serviced frequently and quickly!) with the cylinder head and
gasket assured of proper alignment.
Studs also provide more accurate and consistent torque
loading. Here’s why. When you use bolts to secure the head,
the fastener is actually being “twisted” while it’s being torqued
to the proper reading. Accordingly, the bolt is reacting to two
different forces simultaneously. A stud should be installed in
a “relaxed” mode – never crank it in tightly using a jammed
nut.
If everything is right, the stud should be installed finger
tight. Then, when applying torque to the nut, the stud will
stretch only on the vertical axis. Remember, an undercut
shorter stud will have a rate similar to a longer, standard shank
stud. This provides a more even clamping force on the head.
Because the head gasket will compress upon initial torquing,
make sure studs and bolts are re-torqued after the engine has
been run.
Rick
Old Nov 14, 2009 | 02:30 PM
GMCtrk's Avatar
dont forget you also have to buy 12 point sockets as well
Old Nov 14, 2009 | 03:34 PM
fastnblu's Avatar
...A 12pt socket has more clamping sirface than a 6pt so there is less chance of stripping a nut.
nut.
been run.
Rick
It was my understandin that a 6pt tends to round off less than a 12pt since each flank is @ 60* instead of every 30*. Quality tools & fasteners I'd imagine wash that worry away.
Nonetheless, I had to use some 12pt bolts on headers on either my older truck or this 1, can't remember which. The 6 pt bolts included w/. headers from header manufacter didn't work in a few instances. Go figure. Cause I wasn't bout to crush/ crease tube for clearance.
Re-torque after running due to compression of gasket. - A person can learn something on PT if they try.
Old Nov 14, 2009 | 06:42 PM
budhayes3's Avatar
PT's Slowest Truck
I agree that the 12 point will make a head swap quicker and easier with the engine in the truck, but if someone's rounding head bolts off they either need better tools or should just drop the tools and step away....If I were building the engine on the stand I'd use 6 point fasteners and a quality SnapOn FlankDrive socket
How much power are you pushing that you need head studs? The LQ9 I'm building is fairly mild, maybe 485 estimated crank HP, so I'm just going to use factory GM torque to yield bolts...torque em once and run with it. If you have to pull the heads off with the engine in the truck, the studs may give you a problem...although the studs in question *should* come out by hand...
