Head gasket recomendation for 243's on 5.3
Old Oct 31, 2016 | 11:02 PM
TPayne03/5.3's Avatar
Default Head gasket recomendation for 243's on 5.3
I have just purchased and milled a set of 243 heads .030 to go on my 2003 Silverado 5.3. I have dished pistons so that is the reason for milling. I am confused however on what head gasket to run. I was just gonna get the stock replacement fel-pro mls HG from oriellys or autozone, but I would like to go thinner around .040 for more compression. Can anyone recommend a good head gasket to run. I hear people recommending an LS1 or LS2 or LS6 gasket, but the cylinder bore size is different than the 5.3 so I am confused. I feel that you would lose compression from the head gasket bore being bigger? Or am I wrong. Thanks in advance!
Old Oct 31, 2016 | 11:19 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Cometic makes an .040
C5788-040
The factory L33 with 799/243 heads use the same bore size gaskets.
Old Nov 1, 2016 | 01:38 AM
marineusmc4's Avatar
C5788-040
Do u mean the LM7? His truck is the same as mine and I have the LM7. And I thought 799/243 heads didn't come stock on trucks til 07? Or am I misinformed? Idk it's 138am and I'm tired lol
Old Nov 1, 2016 | 10:31 AM
1FastBrick's Avatar
No I mean an L33. It's an aluminum 5.3L. It uses 4.8 pistons and has 799/243 heads from the factory.
They had 3 different 5.3L's for the silverado depending on the year.
LM7 standard 5.3L
L59 basically the same long block but flex fuel capable.
L33 high output 5.3L - 2005-2007 extended cab 4x4 only
when they switched to Gen 4 engines in the GMT 900 platforum is when you got 799/243 standard on the 5.3L but the RPO codes were different.
https://en.wikipedia.org/wiki/LS_bas...l-block_engine
Old Nov 1, 2016 | 12:03 PM
LM7 standard 5.3L
learn something new everyday lol
Old Nov 1, 2016 | 01:26 PM
C5788-040
Yeah I found the cometic on summit, but my concern is that the thickness is good at .040 but the bore is 3.910 and my cylinder bore is 3.78 that's a 0.130 over bore. Wouldn't the over bore of 0.130 cancel out the compression I would gain from the thinner gasket. The stock replacement fel-pro gasket is 0.051 thick and 3.835 bore. That makes a lot smaller over bore at 0.055. I've always read that some overbore is good but anything past .060 on the gasket will cause you to loose noticeable compression.
Old Nov 1, 2016 | 02:08 PM
1FastBrick's Avatar
Gm runs a gasket like that on the L33. I believe it's to compensate for the larger combustion chamber.
GM part number 12589226 is a single 12498544 is a pair.
They use the same head gasket on the 5.7L LS1
Old Nov 1, 2016 | 02:10 PM
1FastBrick's Avatar
You would have to look at a compression calculator that takes that into account.
Cometic will make you a custom set in any bore size and thickness you specify.
Old Nov 1, 2016 | 07:34 PM
Called Cometic and I had them make me a set. .040 compressed thickness and 3.810 bore, that's gonna make some nice compression. Wasn't cheap lol $180, but you gotta pay to play I guess. 🙌🏻
Old Nov 1, 2016 | 07:54 PM
1FastBrick's Avatar
Originally Posted by TPayne03/5.3
Called Cometic and I had them make me a set. .040 compressed thickness and 3.810 bore, that's gonna make some nice compression. Wasn't cheap lol $180, but you gotta pay to play I guess. ����
Sure do!!!
I ordered the last pair summit had in stock of the C5788-040 a few weeks back.
I noticed the date keeps getting moved back on when they will be available...
