head diffs?
Old May 26, 2009 | 08:38 PM
05gibbs's Avatar
Default head diffs?
i have a 05 chevy truck with a 5.3 and i got a blown up ls1 given to me and the top end is good was wondering what the diff in the heads were? what valves and combustion chamber is in both and i plan on getting one set built just want to know the specs on both heads
Old May 26, 2009 | 09:32 PM
Mangled03gmc's Avatar
Baltimore Whore
97-2000 ls1 heads were 241 or 853 heads and 2001 up- had ls6 243 heads... 5.3 heads 706 & 852 & 862
241 and 853 heads
chamber Volume:66.67cc
Comp Ratio:10.1:1
Intake Volume:200cc
Exhaust Volume:70cc
Intake valve Diameter:2.00-in
Exhaust valve Diameter:1.55-in
243-(ls6)
Chamber Volume:64.45cc
Compression Ratio:10.5:1
Intake Volume:210cc
Exhaust Volume:75cc
5.3
706 & 852 & 862
Combustion chamber Volume:61.15cc
Compression Ratio:9.5:1
Intake port Volume:200cc
Exhaust Port Volume:70cc
Intake valve Diameter:1.89-in
Old May 26, 2009 | 09:53 PM
05gibbs's Avatar
thanks very much so it would be a good swap for when i get a pro charger so i can run more boost and flow better right?
5.3Okasai
Mar 9, 2022 01:07 PM
ARC
57
Feb 21, 2022 10:54 AM
BCraven1018
37
Dec 20, 2016 11:46 AM
chopperloco
Jul 10, 2016 10:45 PM
vmaxpro
Aug 8, 2015 10:49 PM
