Head Cam Swap
Old Mar 7, 2007 | 10:22 PM
ByuTrukr's Avatar
formerly ByuTrukFreak
Default Head Cam Swap
Patriot Heads: w/2.02" Int 1.57" Ex Patriot Gold Dual .650" Lift Springs flow 292-296@.600 lift
Patriot Cam: 226/226 Duration @.050" .585"/.585" Lift @ 112 LSA
I will use the stock rocker arm with hardened pushrods (stock length).Will also be changing to LT's,no cats.
Should I change the lifters and should I change the intake? Any suggestions welcome. Thanx, Brian
Old Mar 7, 2007 | 10:59 PM
BLACK04VHO's Avatar
Ii would go ahead and change the intake for those higher lift numbers on the cam.
Old Mar 7, 2007 | 11:03 PM
AustinDesigns's Avatar
You don't have to change the lifters. With that cam, I don't know if I would change the intake out or not. I'm not changing mine out yet, gonna see what the numbers look like on the dyno first. Then, we MIGHT change it to a Victor Jr, if the numbers aren't what we're expecting. But I would try the truck intake out first, if it falls on it's face like everyone says, then buy a different one.
Old Mar 8, 2007 | 07:23 AM
ByuTrukr's Avatar
How bout some suggestions for an intake.
Old Mar 8, 2007 | 08:04 AM
ap2002's Avatar
thats a big cam, it will work good if you go with a 3500+converter.
Old Mar 8, 2007 | 08:26 AM
ByuTrukr's Avatar
The guy at Patriot said the powerband is 2000-5800 what's your opinion on that? Any suggestions on an intake.
Old Mar 8, 2007 | 08:38 AM
v8
17,16,15,14,13,12,11 Drvr
thats the same cam i'm running, 3k stall would be nice with it, I shift out at 6800 with it.
Old Mar 8, 2007 | 08:45 AM
onebadrubi's Avatar
Tan327 ran that cam wtih a TT3000. thats a tight 3000 stall converter. FInd you a loose 3200 or 3400, he is rcsb, and his truck would have been pullin alot harder out of the hlole.
Old Mar 8, 2007 | 09:30 AM
ByuTrukr's Avatar
I have a 16' checkmate that i still need to tow. i will use a 10.5 vig with the 3 disc how much stall is it possible to tow with? This boat can't weigh much more than 1500 lbs.
Old Mar 8, 2007 | 09:43 AM
silver-mod-o's Avatar
Hunt&Fisherator
if you are towing like that I would do a slightly smaller cam maybe like a 222 or 224, and go with a TT3000, thats a good converter to tow with occasionally...
