Head bolts
Old Jan 27, 2005 | 10:03 PM
Default Head bolts
I heard that if you pull the heads off on our trucks when you put them back on your suposed to use new head bolts. Also how does every one torque their heads down? GM Says to use a torque angle meter???
Old Jan 27, 2005 | 10:09 PM
you NEED new head bolts. they are stretch head bolts. they stretch when you torque them down. and yes, you need a torque angle meter.
Old Jan 27, 2005 | 10:13 PM
ok going to try and not pull the heads off. Going to install new cam,springs,lifters,ect. soon.
Old Jan 27, 2005 | 10:17 PM
KLUG'S SS's Avatar
FormerVendor
If you are going to change the lifters you have to pull the heads.
Old Jan 27, 2005 | 10:32 PM
or a hole-saw
Old Jan 27, 2005 | 11:09 PM
not real sure yet just thinking about it
Old Jan 28, 2005 | 01:20 AM
Yelo's Avatar
You don't NEED an angle-gauge but it makes life a little simpler if you have one, check out jmx's write-up at www.ls1howto.com ...he has probably the best heads/cam swap info page there is....and if you have any questions you can PM him because he's a member here too
Old Jan 28, 2005 | 09:04 AM
Scream's Avatar
MOOBIES Moderator
Might be a good time to get some reusable bolts like the ARP's while you've got the heads off.
slowlsx
Aug 10, 2015 05:33 PM
Denali08
Aug 9, 2015 04:34 PM
signguy62
Jul 27, 2015 03:42 PM
fat tony157
Jul 16, 2015 12:35 PM
