Which HD radiator to get??
Old Nov 18, 2003 | 12:27 PM
ranwalk's Avatar
Default Which HD radiator to get??
I'm thinking of upgrading my radiator to the larger HD one. What should I get?? With or without oil cooler? I have the oil cooler lines that came with my 6.0 swap so I could install them, but is there any REAL benifit from it??
Old Nov 18, 2003 | 12:37 PM
Hit Man X's Avatar
I have the 34" rad w/o the oil cooler, just the trans cooler. If you have the lines and just require the rad for the oil cooler I'd install the oil cooler too. I think the price is negligable.
REAL benefit, just a slightly cooler oiling system. I think oil temps need to be around 180-220* F for optimal wear and such. If you get too hot down there you will burn the oil...since you are FI with a large motor I'd say cooling down your motor in the most efficient way possible is a good idea.
Hope that helps...
Old Nov 18, 2003 | 01:14 PM
OBXMarine's Avatar
When I upgraded mine, I miss ordered the 34" radiator with the oil cooler and it was cheaper than the 34" w/o the oil cooler.
Old Nov 19, 2003 | 10:38 AM
L82gofast's Avatar
Just get the one with the oil cooler. If you decide not to hook it up, no big deal. But it will be nice to have it. Cool oil is a good thing.
Tigger Welder
Oct 1, 2015 08:41 AM
old motorhead
Sep 29, 2015 08:22 PM
TrickTurbo
Sep 25, 2015 11:22 AM
whitelazer
Sep 22, 2015 09:38 PM
