Have A Tranny Question!!!!!!!!!
#22
so basicly the 700R4E should NOT be in my friends truck. if thats really in there. yah, if he goes to the bone yard i told him to get a 4L80E and have that built. thanks everyone for all the info. if anyone has anymore info for me the more the better. i just want to get my friends tranny problem fixed!!!
#23
Actually if it is a old 700R4 they are trouble prone until modified properly. As far as trannies, I would look for a 4L60 instead because it has a 3.09 first gear vs the 80's 2.48 which will make a big difference in low speed launchs.
#24
#27
Originally Posted by 02denali
if it ids the 700r4 how in the hell is the computer running it since it is controlled differently. you should have a check engine light on.
Not sure what he has without seeing it. It may even be a hybrid the shop slapped together. He needs to go to a different shop too.
#29
The 700 is not supposed to be in there. I don't care how much alike they are, they aren't the same!
Is your bud running any power adders? If not, I would get a stock 60e, put a TransGo shift kit in it and a set of servos. Be conservative with the shift kit and even more if you use billet servos.
WHatever you do, don't let that shop touch his truck again.
#30
No really difference strength wise and I myself prefer the late model 700R4. Also, you have to watch those shift kits as the stock sprags in the 700R4/4L60 are not that strong. They hold up fine with resonably stock shifts and mild pressure boost but if you bang shifts too hard for long with a "kit" without upgrading sprag you will trash the tranny and it will be catastrophic when it fails too.
