has anyone found a cost effective way to swap to an LS6 intake?
Old Jul 26, 2006 | 01:07 PM
  #31
well if anyonw want i have these parts for sale for a intake swap
05 SSR LS2 90mm intake has been professionally ported $300
06 Corvette 90mm throttle body $365
02 TAC $110
Speartech wiring harness adapter to connect to the 90mm tb to stock tb wiring harness $45
05 SSR Fuel Rails for 04-newer trucks $90
Old Jul 26, 2006 | 02:14 PM
  #32
Yelo's Avatar
Wish I could afford it right now.....
Old Jul 26, 2006 | 02:57 PM
  #33
TigerFan187's Avatar
Originally Posted by tdrumm
Did your 97/98 vette rail not come with the FPR? Also, where did you get it?
PM on its way!
Old Jul 26, 2006 | 06:28 PM
  #34
Dark Halo's Avatar
02 TAC $110
If I can sell my slicks I may be able to get the intake for sure.
Old Jul 26, 2006 | 08:22 PM
  #35
BADMOFO's Avatar
Cuz I AM a BADMOFO
Does anyone like the Edelbrock carb. intake with an intake elbow? If I was going to do any it would be that.
Old Jul 26, 2006 | 08:32 PM
  #36
i have heard it does not make good power untill it hits high rpm
Old Jul 26, 2006 | 08:43 PM
  #37
Going with a LS6 is definitely cheaper than going with something like a FAST.
I just did the 90mm FAST with the GM 90mm TB. Along with that, FAST fuel rails, aftermarket FPR. All in all, around $1800. So I think $5-800 is a good deal.
The GM 90mm TB (GM # 12570790) can be had for $299.95 at SDPC2000.com - brand new. The TAC module (GM # 12574221) is $145.
You guys should go to KANO's thread. To get his rails and injectors to work he essentially bolted a strip of metal to the stock location of the rails bolt-downs. Then just drilled holes and bolted the truck rails to it. That is not high on the fab difficulty list when all you need to do is cut two strips of metal and drill a few holes. He had to do a few other things that for the most part were fairly simple.
If any of you guys need one of the Speartech brackets, I have an extra that I'll sell for $60 shipped. Never used.
Old Jul 27, 2006 | 06:05 AM
  #38
tdrumm's Avatar
How is the throttle resonse with the FAST? Were you running the truck intake on your stroker prior to the FAST? I bet the swap made a huge difference.
Old Jul 27, 2006 | 12:54 PM
  #39
SS_bnoon_SS's Avatar
$235.38 from gmpartsdirect.com for the same part brand new.
SOLD if you can take paypal. PM sent!
Old Jul 27, 2006 | 04:10 PM
  #40
I had the truck intake on before. Throttle response is incredibly quicker. Acceleration is very smooth and it idles better, and at very low rpms/low speed it is much quieter. Can't give an opinion on power change yet, still working on cruise tuning. I'll know how power is by the end of the weekend coming up.
