Has anbody milled 317's to 64cc
Old Aug 8, 2007 | 04:56 PM
98catfish's Avatar
Default Has anbody milled 317's to 64cc
Like the title says. I have an 05 low mile lq4 and i want to have the stock 317's milled to 64cc. My question is what are the down side to this.
I'm on a tight budget and this seems to be a good way to get my formula up and running and is cheap.
Old Aug 8, 2007 | 07:58 PM
Richard@WCCH's Avatar
FormerVendor
If you mill .040" you'll get real close to your target 64cc. You'll need to run a set of .050" shorter pushrods too.
Richard
Old Aug 9, 2007 | 06:10 PM
98catfish's Avatar
Thanks Richard if I use an aftermarket cam with a smaller base circle wouldnt that put me back to stock length or very close anyway?
Also with the dished lq4 piston would I be less likely to have ptv issues with say a g5x3 or ms4?
Old Aug 9, 2007 | 10:26 PM
Quik's Avatar
5 year bitches!
always check with a pushrod checker once you mill the heads.
Old Aug 10, 2007 | 09:07 AM
FormerVendor
Never assume. Always mock up and check before final assembly.
Good luck,
Richard
zblee
Nov 11, 2015 12:41 AM
turbo6c3
Oct 5, 2015 06:11 PM
someotherguy
Oct 5, 2015 12:49 PM
gmcyukon
Oct 3, 2015 11:03 PM
old motorhead
Sep 29, 2015 08:22 PM
