hard start?
Old Mar 17, 2007 | 05:38 PM
seeyaa's Avatar
Default hard start?
hey guys ive had a problem with the truck ever since i put the nnew motor and cam ,trans Ect. it starts fine when cold but once it warms up and sits for a sec it cranks real hard and slow like a dead battery. its a new battery,alt charging fine. any advice?
Old Mar 17, 2007 | 05:43 PM
Derek @ EDO's Avatar
FormerVendor
possibly the fuel pressure regulator, the brass looking thing on the fuel rail. Pull off the hose while the engine is running, if fuel comes out the regulator replace the whole regulator and that should fix the problem.
Old Mar 17, 2007 | 05:50 PM
seeyaa's Avatar
u think so that seem too easy. it only does it when its hot never cold
Old Mar 17, 2007 | 05:55 PM
FormerVendor
it would take 5 minutes to see if thats the problem, it very well can be!
Old Mar 17, 2007 | 06:19 PM
seeyaa's Avatar
just went out and checked no fuel comming out its almost like the timming is to far advanced but i have no why to check that
Old Mar 17, 2007 | 06:22 PM
FormerVendor
have you tried jumping it off when warm?
Does it start right up?
Old Mar 17, 2007 | 06:29 PM
seeyaa's Avatar
it still cranks hard. when you try to jump it
Old Mar 17, 2007 | 07:19 PM
BlownChevy's Avatar
blownerator
25 Year Member
could be several things.....FPR is one as stated above, the other could be a bad engine ground from when you did the engine swap. I would not rule out the FPR yet, do some more checking and report back.
BTW best way to check the FPR is with a pressure gauge. No less than 58 psi at the rail with the KOEO.
Old Mar 18, 2007 | 06:04 AM
seeyaa's Avatar
sounds like i need to get fuel prressure gauge and report back.
SLOPONY
20
Oct 18, 2016 06:05 AM
treylittlefield
Jan 24, 2016 07:38 PM
mz00516
Aug 23, 2015 12:19 PM
steves86ta
Jul 28, 2015 10:21 AM
banker099
Jul 4, 2015 05:50 PM
